HATA KODLARI (Bilgilendirme) |
CemDemiral
1. Vites Yaşı : 34 Aracı : 2007 - 207 1.4 HDİ Trendy Kayıt Tarihi: 06 Nisan 2017 Konum: Ankara Durum: Aktif Değil Mesajlar: 161 |
Alıntı CemDemiral
Gönderim Zamanı: 02 Haziran 2017 Saat 10:58 |
ALINTIDIR !.. Peugeot Arıza Kodları ve Anlamları P0101 KUTLE HAVA AKIS DEVRE SINIRI / PERFORMANS
SORUNU P0102 MAF DEVRE DUSUK GiRiSi P0103 MAF DEVRE YUKSEK GiRiSi P0104 MAF DEVRE ARALIGI P0105 MAP/BP DEVRE ARIZASI P0106 MAP/BP SENSOR SINIRI/PERFORMANS SORUNU P0107 MAP/BP SENSOR DUSUK GiRiSi P0108 MAP/BP SENSOR YUKSEK GiRiSi P0109 MAP/BP DEVRE ARALIKLARI P0110 IAT DEVRE ARIZASI P0111 IAT DEVRE SINIRI /PERFORMANS SORUNU P0112 IAT DEVRE DUSUK GiRiSi P0113 IAT DEVRE YUKSEK GiRiSi P0114 IAT DEVRE ARALIKLARI P0115 ECT DEVRE ARIZASI P0116 ECT DEVRE SINIRI /PERFORMANS SORUNU P0117 ECT DEVRE DUSUK GiRiSi P0118 ECT DEVRE YUKSEK GiRiSi P0119 ECT DEVRE ARALIKLARI P0120 TP SENSOR A DEVRE ARIZASI P0121 TP SENSOR A SINIRI /PERFORMANS SORUNU P0122 TP SENSOR A DUSUK GiRiS P0123 TP SENSOR A YUKSEK GiRiS P0124 TP SENSOR A DEVRE ARALIKLARI Düzenleyen CemDemiral - 02 Haziran 2017 Saat 11:01 |
CemDemiral
Alıntı CemDemiral
P0125 KAPALI DEVRE YAKIT KONTROLU ICiN YETERSiZ
SOGUTMA SIVISI ISISI P0126 SABiT CALISMA ICiN YETERSiZ SOGUTMA SIVISI P0128 SOGUTMA SIVISI TERMOSTAT ARIZASI P0130 ISITILMIS 02 SENSORU DEVRE ARIZASI (BANK 1,
SENSOR 1) P0131 ISITILMIS 02 SENSORU DUSUK VOLTAJ (BANK 1,
SENSOR 1) P0132 ISITILMIS 02 SENSOR DEVRESi YUKSEK VOLTAJ
(BANK 1, SENSOR 1) P0133 ISITILMIS 02 SENSOR DEVRESi YAVAS TEPKi
(BANK 1, SENSOR 1) P0134 ISITILMIS 02 SENSOR DEVRESiNDE HAREKETLiLiK
TESPiT EDiLEMEDi (BANK 1, SENSOR 1) P0135 ISITILMIS 02 SENSOR ISITICI DEVRE ARIZASI
(BANK 1, SENSOR 1) P0136 ISITILMIS 02 SENSOR DEVRESi ARIZASI (BANK
1, SENSOR 2) P0137 ISITILMIS 02 SENSOR DEVRESi DUSUK VOLTAJ
(BANK 1, SENSOR 2) P0138 ISITILMIS 02 SENSOR DEVRESi YUKSEK VOLTAJ
(BANK 1, SENSOR 2) P0139 ISITILMIS 02 SENSOR DEVRESi YAVAS TEPKi
(BANK 1, SENSOR 2) P0140 ISITILMIS 02 SENSOR DEVRESi HAREKETLiLiK
TESPiT EDiLEMEDi (BANK 1, SENSOR 2) P0141 ISITILMIS 02 SENSOR ISITICI DEVRESi ARIZASI
(BANK 1, SENSOR 2) P0142 ISITILMIS 02 SENSOR DEVRESi ARIZASI (BANK
1, SENSOR 3) P0143 ISITILMIS 02 SENSOR DEVRESi DUSUK VOLTAJ
(BANK 1, SENSOR 3) P0144 ISITILMIS 02 SENSOR DEVRESi YUKSEK VOLTAJ
(BANK 1, SENSOR 3) P0145 ISITILMIS 02 SENSOR DEVRESi YAVAS TEPKi
(BANK 1, SENSOR 3) P0146 ISITILMIS 02 SENSOR DEVRESi HAREKETLiLiK
TESPiT EDiLEMEDi (BANK 1, SENSOR 3) P0147 ISITILMIS 02 SENSOR ISITICI DEVRESi ARIZASI
(BANK 1, SENSOR 3) P0150 ISITILMIS 02 SENSOR DEVRE ARIZASI (BANK 2,
SENSOR 1) P0151 ISITILMIS 02 SENSOR DEVRESi DUSUK VOLTAJ
(BANK 2, SENSOR 1) P0152 ISITILMIS 02 SENSOR DEVRESi YUKSEK VOLTAJ
(BANK 2, SENSOR 1) P0153 ISITILMIS 02 SENSOR DEVRESi YAVAS TEPKi
(BANK 2, SENSOR 1) P0154 ISITILMIS 02 SENSOR DEVRESi HAREKETLiLiK
TESPiT EDiLMEDi (BANK 2, SENSOR 1) P0155 ISITILMIS 02 SENSOR ISITICI DEVRESi ARIZASI
(BANK 2, SENSOR 1) P0156 ISITILMIS 02 SENSOR DEVRE ARIZASI (BANK 2,
SENSOR 1) P0157 ISITILMIS 02 SENSOR DEVRESi DUSUK VOLTAJ
(BANK 2, SENSOR 2) P0158 ISITILMIS 02 SENSOR DEVRESi YUKSEK VOLTAJ
(BANK 2, SENSOR 2) P0159 ISITILMIS 02 SENSOR DEVRESi YAVAS TEPKi
(BANK 2, SENSOR 2) P0160 ISITILMIS 02 SENSOR DEVRESi HAREKETLiLiK
TESPiT EDiLEMEDi (BANK 2, SENSOR 2) P0161 ISITILMIS 02 SENSOR ISITICI DEVRESi ARIZASI
(BANK 2, SENSOR 2) P0170 YAKIT AYAR ARIZASI (BANK 1) P0171 SiSTEM COK ZAYIF (BANK 1) P0172 SiSTEM COK ZENGiN (BANK 1) P0173 YAKIT AYAR ARIZASI (BANK 2) P0174 SiSTEM COK ZAYIF (BANK 2) P0175 SiSTEM COK ZENGiN (BANK 2) P0176 YAKIT KARISIM SENSOR DEVRE ARIZASI P0177 YAKIT KARISIM SENSOR DEVRE
SINIRI/PERFORMANSI P0178 YAKIT KARISIM SENSOR DEVRESi DUSUK GiRiSi P0179 YAKIT KARISIM SENSOR DEVRESi YUKSEK GiRiSi P0180 YAKIT ISI SENSORU A DEVRESi ARIZASI P0181 YAKIT ISI SENSORU A DEVRESi SINIRI/PERFORMANSI P0182 YAKIT ISI SENSORU A DEVRESi DUSUK GiRiSi P0183 YAKIT ISI SENSORU A DEVRESi YUKSEK GiRiSi |
CemDemiral
Alıntı CemDemiral
P0185 YAKIT ISI SENSORU B DEVRESi ARIZASI P0186 YAKIT ISI SENSORU B DEVRESi
SINIRI/PERFORMANSI ARIZASI P0187 YAKIT ISI SENSORU B DEVRESi DUSUK GiRiS P0188 YAKIT ISI SENSORU B DEVRESi YUKSEK GiRiS P0189 YAKIT ISI SENSORU B DEVRESi ARALIKLARI P0190 YAKIT HATTI BASINC SENSOR DEVRE ARIZASI P0191 YAKIT HATTI BASINC SENSOR DEVRE
SINIRI/PERFORMANSI P0192 YAKIT HATTI BASINC SENSOR DEVRE DUSUK
GiRiSi P0193 YAKIT HATTI BASINC SENSOR DEVRE YUKSEK
GiRiSi P0195 MOTOR YAGI ISI SENSORU DEVRE ARIZASI P0196 MOTOR YAGI ISI SENSORU SINIRI/PERFORMANSI P0197 MOTOR YAGI ISI SENSORU DUSUK P0198 MOTOR YAGI ISI SENSORU YUKSEK P0199 MOTOR YAGI ISI SENSORU ARALIKLARI P0200 ENJEKTOR DEVRE ARIZASI P0201 ENJEKTOR DEVRE ARIZASI-SiLiNDiR #1 P0202 ENJEKTOR DEVRE ARIZASI-SiLiNDiR #2 P0203 ENJEKTOR DEVRE ARIZASI-SiLiNDiR #3 P0204 ENJEKTOR DEVRE ARIZASI-SiLiNDiR #4 P0205 ENJEKTOR DEVRE ARIZASI-SiLiNDiR #5 P0206 ENJEKTOR DEVRE ARIZASI-SiLiNDiR #6 P0207 ENJEKTOR DEVRE ARIZASI-SiLiNDiR #7 P0208 ENJEKTOR DEVRE ARIZASI-SiLiNDiR #8 P0209 ENJEKTOR DEVRE ARIZASI-SiLiNDiR #9 P0210 ENJEKTOR DEVRE ARIZASI-SiLiNDiR #10 P0211 ENJEKTOR DEVRE ARIZASI-SiLiNDiR #11 P0212 ENJEKTOR DEVRE ARIZASI-SiLiNDiR #12 P0213 SOGUK CALISTIRMA ENJEKTORU #1 ARIZA P0214 SOGUK CALISTIRMA ENJEKTORU #2 ARIZA P0215 MOTOR DURDURMA SELENOiD ARIZASI P0216 ENJEKSiYON ZAMANLAMA KONTROL DEVRESi ARIZASI P0217 MOTOR ASIRI HARARET DURUMU P0218 SANZIMAN ASIRI HARARET DURUMU P0219 MOTOR ASIRI HIZ DURUMU P0220 GAZ /PEDAL YERi SENSOR/DUGME B DEVRESi
ARIZASI P0221 GAZ /PEDAL YERi SENSOR/DUGME B PERFORMANS
SORUNU P0222 GAZ YERiNiN SENSORU B DEVRESi DUSUK GiRiSi P0223 GAZ YERiNiN SENSORU B DEVRESi YUKSEK GiRiSi P0224 GAZ YERiNiN SENSORU B ARALIKLARI P0225 GAZ YERiNiN SENSORU C DEVRESi ARIZASI P0227 GAZ YERiNiN SENSORU C DEVRESi DUSUK GiRiSi P0228 GAZ YERiNiN SENSORU C DEVRESi YUKSEK GiRiSi P0229 GAZ YERiNiN SENSORU C ARALIKLARI P0230 YAKIT POMPASI BiRiNCiL DEVRE ARIZASI P0231 YAKIT POMPASI IKiNCiL DEVRESi DUSUK P0232 YAKIT POMPASI IKiNCiL DEVRESi YUKSEK P0233 YAKIT POMPASI IKiNCiL DEVRESi ARALIKLARI P0234 MOTORUN COK FAZLA CALISMIS DURUMU P0235 TURBO SARJ DESTEK SENSORU A DEVRE ARIZASI P0236 TURBO SARJ DESTEK SENSORU A PERFORMANSI |
CemDemiral
Alıntı CemDemiral
P0237 TURBO SARJ DESTEK SENSORU A DEVRESi DUSUK P0238 TURBO SARJ DESTEK SENSORU A DEVRESi YUKSEK P0239 TURBO SARJ DESTEK SENSORU B DEVRE ARIZASI P0240 TURBO SARJ DESTEK SENSORU B DEVRE SINIRI
/PERFORMANS P0241 TURBO SARJ DESTEK SENSORU B DEVRESi DUSUK P0242 TURBO SARJ DESTEK SENSORU B DEVRESi YUKSEK P0243 ATIK KAPISI SELENOiDi A ARIZALI P0244 ATIK KAPISI SELENOiDi A SINIRI /
PERFORMANSI P0245 ATIK KAPISI SELENOiDi A DUSUK P0246 ATIK KAPISI SELENOiDi A YUKSEK P0247 ATIK KAPISI SELENOiDi B ARIZALI P0248 ATIK KAPISI SELENOiDi B SINIRI /
PERFORMANSI P0249 ATIK KAPISI SELENOiDi B DUSUK P0250 ATIK KAPISI SELENOiDi B YUKSEK P0251 ENJEKSiYON POMPASI YAKIT OLCUM KONTROL A
ARIZASI P0252 ENJEKSiYON POMPASI YAKIT OLCUM KONTROL A
SINIRI/ PERFORMANSI P0253 ENJEKSiYON POMPASI YAKIT OLCUM KONTROL A
DUSUK P0254 ENJEKSiYON POMPASI YAKIT OLCUM KONTROL A
YUKSEK P0255 ENJEKSiYON POMPASI YAKIT OLCUM KONTROL A
ARALIKLARI P0256 ENJEKSiYON POMPASI YAKIT OLCUM KONTROL B
ARIZASI P0257 ENJEKSiYON POMPASI YAKIT OLCUM KONTROL B
SINIRI / PERFORMANSI |
CemDemiral
Alıntı CemDemiral
P0286 ENJEKTOR DEVRESi YUKSEK-SiLiNDiR #9 P0287 SiLiNDiR #9 BALANS HATASI P0288 ENJEKTOR DEVRESi DUSUK-SiLiNDiR #10 P0289 ENJEKTOR DEVRESi YUKSEK-SiLiNDiR #10 P0290 SiLiNDiR #10 BALANS HATASI P0291 ENJEKTOR DEVRESi DUSUK-SiLiNDiR #11 P0292 ENJEKTOR DEVRESi YUKSEK-SiLiNDiR #11 P0293 SiLiNDiR #11 BALANS HATASI P0294 ENJEKTOR DEVRESi DUSUK-SiLiNDiR #12 P0295 ENJEKTOR DEVRESi YUKSEK-SiLiNDiR #12 P0296 SiLiNDiR #12 BALANS HATASI P0300 ARALIKLI ATESLEME HATASI TESPiT EDiLDi P0301 SiLiNDiR # 1 ATESLEME HATASI TESPiT EDiLDi P0302 SiLiNDiR # 2 ATESLEME HATASI TESPiT EDiLDi P0303 SiLiNDiR # 3 ATESLEME HATASI TESPiT EDiLDi P0304 SiLiNDiR # 4 ATESLEME HATASI TESPiT EDiLDi P0305 SiLiNDiR # 5 ATESLEME HATASI TESPiT EDiLDi P0306 SiLiNDiR # 6 ATESLEME HATASI TESPiT EDiLDi P0307 SiLiNDiR # 7 ATESLEME HATASI TESPiT EDiLDi P0308 SiLiNDiR # 8 ATESLEME HATASI TESPiT EDiLDi P0309 SiLiNDiR # 9 ATESLEME HATASI TESPiT EDiLDi P0310 SiLiNDiR # 10 ATESLEME HATASI TESPiT EDiLDi P0311 SiLiNDiR # 11 ATESLEME HATASI TESPiT EDiLDi P0312 SiLiNDiR # 12 ATESLEME HATASI TESPiT EDiLDi P0320 ATESLEME MOTOR HIZ GiRiS DEVRE ARIZASI P0321 ATESLEME MOTOR HIZ GiRiS DEVRE SINIRI/
PERFORMANSI P0322 ATESLEME MOTOR HIZ GiRiS DEVRE SiNYAL YOK P0323 ATESLEME MOTOR HIZ GiRiS DEVRE ARALIKLARI P0325 VURUNTU SENSORU 1 DEVRE ARIZASI P0326 VURUNTU SENSORU 1 DEVRE SINIRI/PERFORMANSI P0327 VURUNTU SENSORU 1 DEVRE DUSUK GiRiSi P0328 VURUNTU SENSORU 1 DEVRE YUKSEK GiRiSi P0329 VURUNTU SENSORU 1 DEVRE ARALIKLARI P0330 VURUNTU SENSORU 2 DEVRE ARIZASI P0331 VURUNTU SENSORU 2 DEVRE SINIRI/PERFORMANSI P0332 VURUNTU SENSORU 2 DEVRE DUSUK GiRiSi P0333 VURUNTU SENSORU 2 DEVRE YUKSEK GiRiSi P0334 VURUNTU SENSORU 2 DEVRE ARALIKLARI P0335 KRANK MiLi YER SENSOR A DEVRESi ARIZASI P0336 KRANK MiLi YER SENSOR A DEVRESi
SINIRI/PERFORMANSI P0337 KRANK MiLi YER SENSOR A DEVRESi DUSUK
GiRiSi P0338 KRANK MiLi YER SENSOR A DEVRESi YUKSEK
GiRiSi P0339 KRANK MiLi YER SENSOR A DEVRESi ARALIKLARI P0340 KAM MiLi YER SENSOR DEVRESi ARIZASI P0341 KAM MiLi YER SENSOR DEVRESi PERFORMANSI P0342 KAM MiLi YER SENSOR DEVRESi DUSUK GiRiSi P0343 KAM MiLi YER SENSOR DEVRESi YUKSEK GiRiSi P0344 KAM MiLi YER SENSOR DEVRESi ARALIKLARI P0350 ATESLEME BOBiNi BiRiNCiL/IKiNCiL DEVRE
ARIZASI P0351 ATESLEME BOBiNi BiRiNCiL A/IKiNCiL DEVRE
ARIZASI |
CemDemiral
Alıntı CemDemiral
Devamını İndirin...
http://dosya.co/i7i0mxkreluv/Hata_Kodları_Devam....docx.html Düzenleyen CemDemiral - 02 Haziran 2017 Saat 11:25 |
ellerine sağlık cem
CemDemiral
Alıntı CemDemiral
Abim devamlı soruluyor en azından ne olduğu bilinsin istedim :)
KILIÇ
GEcmiş konulara bakan cok az kişi var yine sorulacak emin olabilirsin :)
doganatak
1. Vites Yaşı : 44 Aracı : 2004 - 206 X Line Kayıt Tarihi: 24 Nisan 2016 Konum: istanbul-ŞİŞLİ Durum: Aktif Değil Mesajlar: 383 |
Alıntı doganatak
Emeğinize sağlık Link çalışmıyor bilginiz olsun
İnstagram: dogan_atak
www.appleturk.com www.tadidamagimdakaldi.com |
LUDACRIS
1. Vites Yaşı : Belirtilmemiş Aracı : Belirtilmemiş Kayıt Tarihi: 21 Mayıs 2017 Konum: Izmir Durum: Aktif Değil Mesajlar: 197 |
Play store da obd2 oto ariza kodlari diye guzel bi uygulama var onada bakim derim arkadaslar
CemDemiral
Alıntı CemDemiral
Link Güncel..
CemDemiral
Alıntı CemDemiral
Umut fakirin ekmeği yapacak bişey yok :)
doganatak
Alıntı doganatak
Teşekkürler indirdim
