  Yeni Mesajlar Yeni Mesajlar RSS - 307 Teknik veriler Detaylı
Mesaj Seçenekleri Mesaj Seçenekleri   Teşekkür (0) Teşekkür(0)   Alıntı Guests Alıntı  Yanıt YazCevapla Mesajın Direkt Linki Konu: 307 Teknik veriler Detaylı
    Gönderim Zamanı: 07 Nisan 2008 Saat 16:37
plain_307.gif%20%281785%20bytes%29
General Information
This page last updated 8 December 2002.
Name Peugeot 307
Code T5
Platform PSA PF2
Production Plants Sochaux & Mulhouse, France.
Introduced March 2001
Powertrain
Engines - Petrol
1.6 Engine
307tu5jp4-s.jpg%20%2847572%20bytes%29
Code TU5JP4
Capacity 1587cc
Bore x Stroke 78.5 x 82 mm
Construction Alloy head (AS7 stabilised aluminium) & sump, cast iron block.
Cylinders 4 Cylinders
Valves 16 Valves. DOHC
Valve Size Intake: 33.1 mm
Exhaust: 24.5 mm
Both have tail rod of 6 mm.
Valve Lift Intake: 8.00 mm
Exhaust: 7.65 mm
Induction Normally Aspirated
Intake Distributor:
Plenum: 1.55 l
Helmholz Resonator: 0.76 l
4 outlets of 320 mm length (40 mm diameter reducing to 35 mm at cylinder head).  Manifold is designed for low end torque.
Fuel System Multipoint Fuel Injection (Bosch EV6 Injectors @ 3.5 BAR)
Bosch ME 7.4.4.
Compression Ratio 11.0 : 1
Power 109BHP / 81kW @ 5750 rpm
Torque 147Nm @ 3900 rpm
Torque Spread 85% (125Nm) from 2000 rpm.
95% (140Nm) between 3300 rpm & 5000 rpm
Oil Capacity 3.0 l
Cooling System Radiator: 21 dm2 (area) / 18 mm (thickness)
200W Dual Speed fan
1.4 BAR degassing chamber
Exhaust System 1. Catalytic Converter directly after exhaust manifold.
2. Intermediate muffler (2.9 l)
3. Rear muffler (15.5 l)
Tailpipe: 45 mm diameter (bent downwards to reduce noise).
Other Crossflow head
Self-adjusting hydraulic tappets (28.4 mm diameter) with anti-return valves - helps to maintain constant oil pressure within themselves and reduce valve noise
Alloy sump reduces vibration and noise.
Electronic throttle butterfly to improve comfort and reduce pollution.
Twin spark ignition - spark plug life 60,000 km.
Ecological oil filter - only need to replace the filter element
Dual oxygen sensor - before and after catalytic converter (chiefly for mixture adjustment)
Introduced 2000
Other Uses Peugeot 206, Partner
Citroen Xsara, C3, Berlingo
TU5JP4 Power & Torque Curve
TU5JP4curve.jpg%20%2848472%20bytes%29
2.0 Engine
307ew10j4-s.jpg%20%2844262%20bytes%29
Code EW10J4
Capacity 1997cc
Bore x Stroke 85 x 88 mm
Construction All alloy.
GS Iron crankshaft
Fuel System Multipoint Sequential Fuel Injection
Magneti Marelli DCM 48 P
Ignition System Sagem BBC 2.2 Twin Spark
Twin Coils.
Power 138BHP / 103kW @ 6000 rpm
Compression Ratio 10.8 : 1
Torque 190Nm @ 4100 rpm
Torque Spread 89% (169Nm) between 1800 rpm & 5750 rpm
Oil Capacity 4.25 l
Cooling System Radiator: 21 dm2 (area) / 21 mm (thickness)
200W Dual Speed fan
Exhaust System 1. Catalytic Converter (1.86 l)
2. Rear Muffler (17.2 l)
Introduced 1999
Other Uses Peugeot 406
Peugeot 206
EW10J4 Power & Torque Curve
EW10J4curve.jpg%20%2845701%20bytes%29
Engines - Diesel
2.0 Engine
307hdi-s.jpg%20%2842901%20bytes%29
Code DW10TD
Capacity 1997cc
Construction Alloy head, cast iron block
Valves 8 Valves. SOHC
Induction Turbocharged (Garett or KKK)
Turbo Boost 1.0 BAR
Fuel System Common Rail Direct Injection
Power 90HP / 67kW @ 4000 rpm
Torque 205Nm @ 1750 rpm
Torque Spread 72% (154Nm) between 1200 rpm & 3400 rpm
Oil Capacity 4.5 l
Cooling System Radiator: 21 dm2 (area) / 26 mm (thickness)
400W Dual Speed fan
Exhaust System 1. Catalyser (2.47 l)
2. Muffler (15.5 l)
Other High Pressure Fuel Rail Pressure:
Siemens ECU: 220 to 1500 BAR
Bosch ECU: 300 to 1350 BAR
Very fine fuel injectors with 5 injection holes each.
Preinjection (< 1 mg) reduces noise by allowing the combustion chamber temperature to rise before main injection.  The system can also inject on demand post injection to burn up any excess fuel in the system.
Introduced March 1999
Other Uses Peugeot 206, 306, 406
DW10TD Power & Torque Curve
DW10TDcurve.jpg%20%2835769%20bytes%29
N.B. 1 HP = 0.7457 kW & 1 kW = 1.341 HP.   kW output is calculated assuming BHP ratings are correct.
All engines meet EURO3 standards.
Engines - Fuel Consumption Figures (AS2877)
These fuel consumption figures are based on Australian Standard 2877, and involve cars tested in a laboratory situation.
City Cycle - This involves a stop and go trip of 12km distance with an average speed of 32 km/h.  It includes a cold start, a warm start, and idle time.
Highway Cycle - This involves a 16.48km trip at an average speed of 77 km/h.  The car is started from warm and this test involves no stopping until the end.
Model (Engine Type) City Cycle (l/100) Highway Cycle (l/100)
307 1.6 Manual (TU5JP4) 7.8 5.2
307 1.6 Auto (TU5JP4) 8.0 5.4
307 2.0 Manual (EW10J4) 8.5 5.4
307 2.0 Auto (EW10J4) 8.0 5.6
307 2.0 HDi Manual (DW10TD) 6.0 4.0
All figures have been entered correctly, the 307 2.0L auto does have a lower city fuel consumption than its manual equivalent.
According to a study, in real life drivers consume 15% more fuel in city driving, and 34% more fuel on highway driving, than the official figures quoted (as above).
Source: Australian Greenhouse Office: Fuel Consumption Guide 2001-2002.
Engines - Pollution Figures
These figures are based on EU directives.
Model (Engine Type) CO2 (g/km) CO (g/km) Moving Noise Level dB(A)
307 1.6 Manual (TU5JP4) 169 0.258 72.4
307 1.6 Auto (TU5JP4) 189 0.962 72.9
307 2.0 Manual (EW10J4) 188 1.068 72.8
307 2.0 Auto (EW10J4) 198 ? ?
307 2.0 HDi Manual (DW10TD) 138 0.542 72.8
Transmissions
Automatic
Code AL 4
Produced At Valenciennes (550 per day)
Type Porsche Tiptronic
Speeds 4 forward gears & 1 reverse gear.
Torque Up to 330Nm
Gear Ratios (1.6 16V) 1st: 2.725
2nd: 1.499
3rd: 1.000
4th: 0.711
Reverse: 2.457
Final Drive: 3.650
Weight 70 kg
Used In Peugeot 206, 307, 307 SW, 406, 807
Citroen Xsara, Berlingo
Manual - 1.4 & 1.6 16V
Code MA/5N
Type Standard
Speeds 5 forward gears & 1 reverse gear.
Clutch Plate 200 mm
Gear Ratios (1.6 16V) 1st: 3.418  (7.24 km/h @ 1000 rpm)
2nd: 1.810  (13.67 km/h @ 1000 rpm)
3rd: 1.276  (19.30 km/h @ 1000 rpm)
4th: 0.975  (25.56 km/h @ 1000 rpm)
5th: 0.767  (32.22 km/h @ 1000 rpm)
Reverse: 3.584
Final Drive: 4.693
Manual - 2.0 16V & 2.0 HDi
Code BE4/5S (2.0 16V)
BE4/5L (2.0 HDi)
Type Standard
Clutch Plate 230 mm
Gear Ratios (2.0 16V) 1st: 3.455?  (8.25 km/h @ 1000 rpm)
2nd: 1.870  (15.24 km/h @ 1000 rpm)
3rd: 1.360  (20.94 km/h @ 1000 rpm)
4th: 1.051  (27.10 km/h @ 1000 rpm)
5th: 0.861  (33.10 km/h @ 1000 rpm)
Reverse: 3.333
Final Drive: 4.054
Gear Ratios (2.0 HDi) 1st: 3.455?  (8.51 km/h @ 1000 rpm)
2nd: 1.870?  (15.72 km/h @ 1000 rpm)
3rd: 1.148  (25.60 km/h @ 1000 rpm)
4th: 0.822  (35.75 km/h @ 1000 rpm)
5th: 0.660  (44.57 km/h @ 1000 rpm)
Reverse: 3.333?
Final Drive: 3.948
Other Hydraulic clutch (wear compensating) & cable shift.
Also used on 306 & 406.
 Chassis
Suspension
Front Inverted pseudo McPherson Struts with triangulated lower wishbone attachments & an uncoupled anti-roll bar.
Wishbone within two rubber joints 268 mm apart - front joint is for steering control (1500 daN stiffness), rear joint for noise suspression (75 daN).
Weight: 19 kg.
Anti Roll Bar: 21 mm in 1.6 16V.  22mm in 2.0 16V & 2.0 HDi.
Rear Deformable U shaped cross member located by two arms and a hollow anti roll bar.
U Torsion Beam thickness: 5-6 mm sheet steel
Anti Roll Bar: External diameter 26 mm, internal diameter 19 mm (hollow)
Dampers (Shock Absorbers) Pressure: 3 BAR (nitrogen gas)
Other System guarantees constant suspension geometry
Steering
Type Variable Rate Electric Power Assisted Rack & Pinion
Lock to Lock 2.9 Turns
Turning Circle 10.75 m between kerbs
11.13 m between walls
Other Electric Power Assistance Pump Speeds:
Parking: 3000 rpm
Maximum: 5000 rpm (eg. during emergencies)
Braking
Type Disc
Features ABS (Bosch 5.3), EBFD, EBA
Front Ventilated. Diameter 283 mm. Thickness 26 mm.
Rear Solid. Diameter 247 mm. Thickness 9 mm.
Callipers Single Piston (54 mm diameter)
Servo Petrol Engines: 10 Inches
Diesel Engines: 9 Inches
Other EBFD distributes braking between front & rear, and between left and right rear wheels.
Indicators activated when deceleration is > 8 m/s/s (28.8km/h/s)
Braking Performance
100-0 km/h AutoBild (FEB02: 307 1.6 16V): 39.2 m (warm) / 41.0 m (cold)
NZ Autocar (JAN02: 307 2.0 16V): 36.15 m
Definitions Cold = 1 application of brakes
Warm = 2 to 10 applications of brakes
Dimensions
External
Length 4202 mm
Width 1746 mm  - 5 door model (mirrors retracted).
1730 mm - 3 door model.
Height 1512 mm
Wheelbase 2608 mm
Front Overhang 878 mm
Rear Overhang 716 mm
Front Track 1505 mm
Rear Track 1510 mm
Steel Thickness 0.6 mm to 4 mm
Drag Coeffcient 0.31
307dimensions-m.jpg%20%2837344%20bytes%29
Cabin
Length Useable: 1696 mm
Front Windshield to Rear Screen: ~ 3 metres
Front Width 1429 mm
Rear Width 1467 mm
Front Headroom 917 mm
Rear Headroom 886 mm
Front Door Opening Angle Detents at 34° & 58°
Other Headroom measurement is from hip joint to roof lining at 14° from the vertical.
Boot
Length 902 mm
Width 1044 mm (between wheel arches)
Loading Height 700 mm
Boot Volume - Seats Up 341 Litres
Boot Volume - Seats Down - Loaded to parcel shelf height 790 Litres
Boot Volume - Seats Down - Loaded to roof height 1328 Litres
Weights
307 Weights (Australian Specification)
Chassis Weight 304 kg
Maximum Roof Load 80 kg
307 XS 1.6 16V Manual Kerb Weight: 1193 kg
307 XS 1.6 16V Automatic Kerb Weight: 1229 kg
Gross Weight: 1729 kg
307 XS 2.0 HDi Manual Kerb Weight: 1260 kg
307 XSE 2.0 16V Manual Kerb Weight: 1219 kg
307 XSE 2.0 16V Automatic Kerb Weight: 1255 kg
307 XSi 2.0 16V Manual Kerb Weight: 1202 kg
307 XSi 2.0 16V Automatic Kerb Weight: 1238 kg
Towing Weights (Braked) 1.4 HDi: 1140 kg
1.4 & 1.6 16V Models: 1200 kg
2.0 16V & HDi (90HP): 1300 kg
2.0 HDi (110HP): 1340 kg
Reduce weights by 10% for every 1000m of altitude
Weights are only permissible within Gross Train Weight.
Weight Distribution 307 1.6 16V: Front 61% / Rear 39%
307 2.0 16V: Front 62% / Rear 38%
Capacities
Fuel Tank 60 l
Fuel pump on petrol models can pump out entire tank capacity & there is no return circuit.
Pipe is welded to tank (no leakage) & shape inhibits outflow.
Washer Fluid Standard: 3.5 l
Headlight Wash Models: 6.5 l
Cabin Information
Front Seating
Seat Offset 345 mm (ie. 690 mm between centre of passengers)
Fore/Aft Travel 230 mm
Height Adjustment 50 mm
Backrest Height 620 mm
Base Cushion Length 510 mm
Seat Pitch 900 - 1100 mm
Seat pitch is the distance from the front of the seat to the firewall.
Rear Seating
Seating Height 370 mm above floor
Backrest Height 590 mm
Base Cushion Length 460 mm
Seat Pitch 600 - 830 mm
Seat pitch is the distance from the front of the seat to the rear of the backrest of the front seat.
Steering Wheel
Height / Reach Adjustment 40 mm
Collapsibility 50 mm (top section) / 95 mm (bottom section).
Airbags
Driver Airbag Smart Airbag with dual gas generators
60 l
Passenger Airbag Smart Airbag with dual gas generators
90 l
Side Airbags 12 l
Curtain Airbags Full length of front and rear side windows
Other Dual gas generators work only when required.  If needed, the second generator will activate 100 ms after the first generator.
Front seat belts are equipped with force limiters to 450 daN.
Rear seat belts are force limited to 650 daN
Sunroof
Dimensions 733.8 x 365 mm
Glass 6% light transmission
4% energy transmission
Other 6 slide positions.  3 tilt positions.
Up to 37.5 mm of tilt travel
 Audio
Head Unit
Code RD3/RB3
Manufacturer Clarion
Type Radio/CD or Radio/Cassette
Power Output 4 x 30W
Frequencies SW, MW (AM), FM
Other 5 disc CD Changer is manufactured by Blaupunkt.
Speakers
Number 6 Speakers.
10 with Hatshelf Subwoofer+Tweeter Accessory System.
Manufacturer ?
Tweeters ?
Front 165mm
Rear ?
Other
Windscreen Wipers
Style Butterfly (center mounted)
Blade Length Right Blade: 700 mm
Left Blade: 650 mm
Rear: 350 mm
Speeds High: 56 wipes/min
Low: 39 wipes/min
Intermittent: Speed variable
Washers Spacing: 250 mm apart
Type: Fluidic fan spray
Other Wipers slow down when vehicle is at a standstill.
Wipers activate 1 second after washer activity.
Can also activate headlights after 10 secs on low mode, 2 secs on high mode, or if 5 wipes have been given in the past 40 seconds.
Colours
Code Type Name
WPPO Standard Banquise White
XLMO Metallic Obsidien Black
GJPO Standard Santorin Blue
GEMO Metallic China Blue
3FMO Metallic Aegean Blue
KBPO Standard Vallelunga Red / Cherry Red
KQMO Metallic Lucifer Red
8MMO Metallic Ouranos Green
8UMP Metallic Oakland Green
ZRMO Metallic Aluminium Grey
ZAMO Metallic Sidobre Grey
C3MO Metallic Persepolis Gold / Sahara Gold
1GMO Metallic Pourpre Lilla
L7MO Metallic Goa Kobber
Colours depend on market. In Europe the 307 is offered with 14 colours. Colour names may differ according to your market.
All images Copyright Peugeot Automobiles Australia
konu icon Fan beyni nerede son mesaja git 5039 5 FERZETE34
konu icon Hızlanma Problemi son mesaja git 6244 1 Evo301
konu icon Peugeot 206 1.4 xr 2000 model arabam var son mesaja git 1307 0 Muhammet Safa07
konu icon BENZİN VE ATEŞLEME ROLESİ son mesaja git 1478 2 Emirhno6
konu icon 1.4 dizel rolanti de klima devrete girip cikma son mesaja git 267 0 heavyburak26
konu icon Bagaj açılmıyor son mesaja git 2181 0 206cc57
konu icon Rifter Gt 2025 tavan lambası son mesaja git 1786 0 Fero13
konu icon 208/207/301 arasinda kaldim son mesaja git 13583 1 aliysnm
konu icon Peugeot 207 Eng Man system Faulty son mesaja git 3495 2 Oğuzhan207
konu icon ENG man system faulty - Hatası (Resimli) son mesaja git 22116 17 Oğuzhan207
konu icon 206 GTI ATEŞLEME PROBLEMİ son mesaja git 2705 0 Emirhno6
konu icon Marş bastığım anda fan açıyor son mesaja git 5510 3 Yunus58
konu icon Pegouet 306 1.8 XR 16 v 1998 son mesaja git 2559 0 Yunus58
konu icon 1.8 XR Usta son mesaja git 9262 1 Yunus58
konu icon 106 gti vites çubukları son mesaja git 17676 2 SerkanPinar
konu icon Mazotta su var uyarisi son mesaja git 13326 5 407aziz
konu icon Klima yönlendirme son mesaja git 4467 2 Ayhan1126
konu icon 306 rolanti problemi son mesaja git 2980 10 yasarseri
konu icon 206 ya kaput amortisörü nasıl yapılır son mesaja git 25286 6 anaykh
konu icon 301 ekranını 2008e takmak son mesaja git 2752 0 tarhansmt
