Alfa Romeo Giulietta - 2010 |
Kifanhom
Kayıt Tarihi: 03 Ocak 2010 Konum: Bursa Durum: Aktif Değil Mesajlar: 304 |
Konu: Alfa Romeo Giulietta - 2010Gönderim Zamanı: 09 Ocak 2010 Saat 00:38 |
Engine Engine Configuration I Cylinders 4 Aspiration/Induction Normal Displacement 2.40 L | 146.4 cu in. | 2399.5 cc. Valves 16 valves. 4 valves per cylinder. Valvetrain SOHC Horsepower 162.00 HP (119.2 KW) @ 6000.00 RPM Torque 162.00 Ft-Lbs (219.7 NM) @ 4000.00 RPM HP / Liter 67.5 BHP / Liter Redline 6500 Compression Ratio 9.5:1 Fuel Type Gasoline - Petrol Fuel Feed Fuel Injected Block Cast-Aluminum Head Aluminum Dimensions Exterior Length 4.351 m | 171.3 in. | 4351 mm. Width 1.801 m | 70.9 in. | 1800.9 mm. Height 1.461 m | 57.5 in. | 1460.5 mm. Wheelbase 2.631 m | 103.6 in. | 2631.4 mm. ![]() ![]() ![]() |
| Sponsor Bağlantı | |
