diagbox 7.82 |
SCREAMN
Kayıt Tarihi: 24 Ekim 2016 Konum: konya Durum: Aktif Değil Mesajlar: 70 |
Konu: diagbox 7.82Gönderim Zamanı: 18 Eylül 2017 Saat 09:12 |
Teşekkürler.
ne kadar yaşadığın değil nasıl yaşadığındır asıl mesele
| Sponsor Bağlantısı | |
maximusti
Kayıt Tarihi: 10 Temmuz 2016 Konum: İstanbul Durum: Aktif Değil Mesajlar: 1207 |
Alıntı maximusti
Gönderim Zamanı: 16 Eylül 2017 Saat 21:08 |
bendeki kurulum notlarına göre:
EN,FR yerine TR yapman gerekiyor.
1. If DiagBox language is french: Open the File Explorer and navigate to "C:\AWRoot\dtrd\trans\", find the file "Language.ini" and create a copy "Language.ini.org". Open the file Language.ini and under [LANGUAGE], change "Current=fr_FR" to "Current=en_GB" and save (I commented the original and added the change from French to English). [LANGUAGE] ;Current=fr_FR Current=en_GB 2a. For DiagBox Lexia (Tested with DiagBox v.7.83): Navigate to "C:\APP\LEXIA\EXE\" and find the file "DICO.TXT". "DICO.TXT" is a read only file, so rename it to "DICO.TXT.org". Create a copy of "DICO.TXT.org" and then the copy rename it to "DICO.TXT". Open the file "DICO.TXT" and change Dico=THELEXBG.DBZ to Dico=THELEXGB.DBZ and save. This is enough to change to english. The following suggested to change only if language not solved from above procedure (probably you didn't do it correct): Navigate to "C:\APP\LEXIA\EXE\" find the file "langue.ini" and create a copy "langue.ini.org". Open the file "langue.ini" and under [DicoMap], change all "%LG%" to GB (I commented the original 4 lines and added changed 4 lines). [DicoMap] ;CITACT=..\Dico\CITACT%LG%.dbz,APV ;CITTT=..\Dico\CITTT%LG%.dbz,APV ;CITTV=..\Dico\CITTV%LG%.dbz,APV ;THESAU=..\Dico\THESAU%LG%.dbz,APV CITACT=..\Dico\CITACTGB.dbz,APV CITTT=..\Dico\CITTTGB.dbz,APV CITTV=..\Dico\CITTVGB.dbz,APV THESAU=..\Dico\THESAUGB.dbz,APV |
SCREAMN
Gönderim Zamanı: 16 Eylül 2017 Saat 01:06 |
Labtopa diagbox yukledim dili Turkceydi ama guncelleme ile 7.82ye yukseltince dil ingilizce oldu nasıl Türkçe yapabilirim
