Anasayfa Anasayfa >PEUGEOT TÜRKİYE MODİFİYE PLATFORMU >Kullanım Klavuzları
  Yeni Mesajlar Yeni Mesajlar RSS - 306 GTI sigorta paneli
hasimayaz Açılır Kutu Gör
P.T. Demirbaş
Kayıt Tarihi: 23 Nisan 2008
Mesaj Seçenekleri Mesaj Seçenekleri   Teşekkür (0) Teşekkür(0)   Alıntı hasimayaz Alıntı  Yanıt YazCevapla Mesajın Direkt Linki Konu: 306 GTI sigorta paneli
    Gönderim Zamanı: 19 Mart 2009 Saat 13:31
306 fuse box under steering column.
F1
10A Radio (On with Ignition)
F1A 10A Radio (Constant on) - NB: 1A means fuse in lower position
F2 5A Instrument panel warning lamps, tachometer, fuel gauge, coolant thermostat, selector lever light (auto.)
F3 15A Fan relay, pressostat, AC compressor cut-off relay
F4 10A Front sidelamps, right tail lamp
F5 10A Heater blower, engine passenger compartment sensor, switch heated rear screen timer.
F6 10A Front fog lamps
F7 20A Cooling fan thermal switch, fan relay, coolant thermostat, horns
F8 Not Usrd
F9 5A Left tail lamp
F10 30A Rear electric window
F11 30A Hood (cabriolet)
F12 10A Instrument panel warning light, starter inhibitor switch and relay, reversing lights, overspeeding buzzer, water in fuel sensor, dim-dips, eingine coolant level sensor
F13 15A Hazard warning
F14 15A Relay supply dipped beam, coded anti-start unit
F15 30A Front and rear courtesy lamp, boot light, infra red receiver, central locking control unit, supply relay low speed fan, coolant temp. unit, thermal switch
F16 20A Cigar lighter (Constant live)
F 16A 20A Cigar lighter (On with ignition) NB: 16A means fuse in lower position
F17 20A Central locking, dead locking unit
F18 10A Rear fog lights
F19 10A Side lamp warning lamp, lights on buzzer. Illumination: clock, switch, instrument panel, radio, cigar lighter.
F20 30A Heated seats
F21 30A AC/heater blower motor, mixing flap motor, air inlet flap motor, AC switch, AC ECU, passenger compartment temp. sensor.
F22 20A Rear wiper, rear interior light (Affaire) central locking control unit, dead locking
F23 Shunt
F24 30A Windscreen wiper front and rear, headlight and screen wash.
F25 5A Clock, radio
F26 20A Electric aerial, caravan socket connector
F27 30A Heated rear screen, heated mirrors. Rear screen demist (cabriolet)
F28 15A Instrument panel warning lamps, additional regulation unit, stop lights, front and rear electric front windows, sun roof, load warning lamp, digital clock, electric hood.
F29 30A Electric front windows, sun roof.
F30 15A Indicators, front and rear interior lights, map reading lamp, vanity mirror lamp, one touch electric window control, infra red receiver, electrically controled mirrors, lights on buzzer
HakanGokdemir Açılır Kutu Gör
Kayıt Tarihi: 30 Temmuz 2008
Mesaj Seçenekleri Mesaj Seçenekleri   Teşekkür (0) Teşekkür(0)   Alıntı HakanGokdemir Alıntı  Yanıt YazCevapla Mesajın Direkt Linki Gönderim Zamanı: 19 Mart 2009 Saat 13:34
Haşim Ayaz ger döndü!!!
Haşim 306gti değil abicim, 306 griffe  için mekale olsun yaa..
Hakan GÖKDEMİR
0 533 215 8019
Pendik / İSTANBUL
26.08.1980
A RH +
Kardeş zorunlu dosttur, Dost seçilmiş kardeştir...
P.T. Demirbaş
Mesaj Seçenekleri Mesaj Seçenekleri   Teşekkür (0) Teşekkür(0)   Alıntı hasimayaz Alıntı  Yanıt YazCevapla Mesajın Direkt Linki Gönderim Zamanı: 19 Mart 2009 Saat 14:04
Orjinalini yazan: hakan1203 hakan1203 Yazdı:
sana ne lazım söyle hemen yazalım :) :)
Mesaj Seçenekleri Mesaj Seçenekleri   Teşekkür (0) Teşekkür(0)   Alıntı HakanGokdemir Alıntı  Yanıt YazCevapla Mesajın Direkt Linki Gönderim Zamanı: 19 Mart 2009 Saat 14:20
Mesela şuan oksijen sensörüm arızalı onun değişimi ile ilgili bulabilirmisin?Wink
Düzenleyen hakan1203 - 19 Mart 2009 Saat 16:34
Hakan GÖKDEMİR
0 533 215 8019
Pendik / İSTANBUL
26.08.1980
A RH +
Mesaj Seçenekleri Mesaj Seçenekleri   Teşekkür (0) Teşekkür(0)   Alıntı Guests Alıntı  Yanıt YazCevapla Mesajın Direkt Linki Gönderim Zamanı: 19 Mart 2009 Saat 14:22
super :):)
mumkunse 307 :)
Emin Açılır Kutu Gör
Kayıt Tarihi: 06 Ağustos 2008
Mesaj Seçenekleri Mesaj Seçenekleri   Teşekkür (0) Teşekkür(0)   Alıntı Emin Alıntı  Yanıt YazCevapla Mesajın Direkt Linki Gönderim Zamanı: 19 Mart 2009 Saat 14:36
Mesela şuan oksijen sesörüm arızalı onun değişimi ile ilgili bulabilirmisin?Wink
Önce sensörü bulmak lazım abi
Mesaj Seçenekleri Mesaj Seçenekleri   Teşekkür (0) Teşekkür(0)   Alıntı HakanGokdemir Alıntı  Yanıt YazCevapla Mesajın Direkt Linki Gönderim Zamanı: 19 Mart 2009 Saat 14:42
   Evet onu gördüm Emin bende ama sensör de ikinci el kullanılmaz Önderoto dan yardım istedim bu konuda fiyat yollayacak. Birde bakalım depodaki benzin bitsinde ondan sonra belli olacak arıza tam sonucu...
Teşekkürler Emin...
Düzenleyen hakan1203 - 19 Mart 2009 Saat 14:43
Hakan GÖKDEMİR
0 533 215 8019
Pendik / İSTANBUL
26.08.1980
A RH +
P.T. Demirbaş
Mesaj Seçenekleri Mesaj Seçenekleri   Teşekkür (0) Teşekkür(0)   Alıntı hasimayaz Alıntı  Yanıt YazCevapla Mesajın Direkt Linki Gönderim Zamanı: 19 Mart 2009 Saat 14:55
şu anda sıkıntısı nedir tam olarak arabanın hakan?
Mesaj Seçenekleri Mesaj Seçenekleri   Teşekkür (0) Teşekkür(0)   Alıntı HakanGokdemir Alıntı  Yanıt YazCevapla Mesajın Direkt Linki Gönderim Zamanı: 19 Mart 2009 Saat 15:01
Orjinalini yazan: hasimayaz hasimayaz Yazdı:
Arabayı aldığımın ikinci günü motor arıza lambası yandı ama bu depoyu fullledikten sonra oluştu 1 gün yandıktan sonra söndü bende umursamadım ama geçtiğimiz cumartesi PT nin halı saha maçına giderken tekrar yandı bende salı günü ancak servise sokabildim. Büyük ihtimal benzinden dediler ancak biz sensöre de baktık ondanda olabilirmiş.
Yine yanabilir o yüzden siz depoyu bitirdikten sonra gelirsiniz o zaman tam tespit yaparız gerekirse oksijen sondajını değişiriz dedi bunları dyen bizim servisteki arkadaş...
Hakan GÖKDEMİR
0 533 215 8019
Pendik / İSTANBUL
26.08.1980
A RH +
P.T. Demirbaş
Mesaj Seçenekleri Mesaj Seçenekleri   Teşekkür (0) Teşekkür(0)   Alıntı hasimayaz Alıntı  Yanıt YazCevapla Mesajın Direkt Linki Gönderim Zamanı: 19 Mart 2009 Saat 15:54
borç yiğidin kamçısıdır hesabı.. Arıza ışığıda pejonun olmazsa olmazıdır :) :).. benimkininde canı ne zaman sıkılsa yanar.. Olur öyle şeyler.. takma kafaya yananlar yansın sağ kalanlar bize yeter.. :) :)
Mesaj Seçenekleri Mesaj Seçenekleri   Teşekkür (0) Teşekkür(0)   Alıntı HakanGokdemir Alıntı  Yanıt YazCevapla Mesajın Direkt Linki Gönderim Zamanı: 19 Mart 2009 Saat 15:56
LOLLOLLOL Aynen Haşim... Ama benzinden bılıyorum ben 206 dada olmuştu Gebze den aldım çünkü benzini...
Hakan GÖKDEMİR
0 533 215 8019
Pendik / İSTANBUL
26.08.1980
A RH +
konu icon 2004 1.4 HDI Klima ile ilgili son mesaja git 274 0 Samet1697
konu icon Lastik basınç sensörü son mesaja git 4 0 DVRM77
konu icon 3008 2022 Far yüksekliği ayarı ve motor titremesi son mesaja git 123 0 berter
konu icon Peugeot 208 GT yeni nesil yakıt tüketimi hk son mesaja git 496 0 mhakan71
konu icon Adblue seviyesini Kaç litre nasıl öğrenirim artık son mesaja git 443 0 Lepromer
konu icon 208 Yağ Azaltma Problemi son mesaja git 6201 8 selahattnsahman
konu icon Peugeot 307 Otomatik Vites Arızası (ÇÖZÜLDÜ) son mesaja git 36603 23 delroy
konu icon Peugeot 307 motor değişimi son mesaja git 180 0 delroy
konu icon Kaput amortisörü son mesaja git 2733 0 Abdullah B.
konu icon 307 çözümsüz hararet problemi son mesaja git 8518 19 talip206
konu icon Stop etme sorunu otomatik 206 son mesaja git 4367 2 konfor
konu icon P0087 Hata kodu son mesaja git 7994 7 konfor
konu icon Gec calisma benzin pompa aorunu son mesaja git 285 0 Arslanalp2000
konu icon 206 2001 model 1.6 motor otomatik şanzıman son mesaja git 3015 3 kralex18
konu icon Pejo206 Çakmak Sigortası son mesaja git 172 0 kralex18
konu icon 3008 1.2 Puretech 130 Eat8 Ateşleme sorunu son mesaja git 12504 7 erthe
konu icon Subap kaldirma valf hatasi son mesaja git 3266 0 Mertdr
konu icon GİDERİLEMEYEN ARIZA son mesaja git 565 0 TİMSAH 71
konu icon GİDERİLEMEYEN ARIZA son mesaja git 247 0 TİMSAH 71
konu icon 207 Coilover & Süspansiyon son mesaja git 3277 0 ShoryuReppa
selahattnsahman 4
talip206 4
konfor 2
delroy 2
TİMSAH 71 2
kralex18 2
a.selim 1
Abdullah B. 1
eRRoR 1
Lepromer 1
