Tires and a few questions |
| 08.05.2020 15:07 | # 1 |
When I came in the evening and looked at my car, the left front wheel was completely lowered and the others had no problem. There are 16 inch wheels. What are the tire sizes and what should be the front rear psi value? When the bidet is going up long slopes, the temperature rises above 90. What do you think is the problem ....?
| 08.05.2020 15:07 | # 2 |
xdesign |
We cannot know the tire standard. Since the 2005 model has changed, not necessarily tires. But generally 307 and Sw 55 205 55 16 are attached. If you look over the tire, it already writes there. 32 ideal for Psi. But I recommend you drop it to 30 in winter conditions. Front and back should be 30. You don't have to worry about overheating. Peugeot and Citroen generally reach maximum grip at 95. But still have his fan checked, etc. You shouldn't be fooled by jokes or prior experience. It is an important issue. |
| 08.05.2020 15:07 | # 3 |
thank you bro .. Last priest 40 pressed wheels are now standing in front of the door on the left front lowered rim :)))
| 08.05.2020 15:07 | # 4 |
xdesign |
The brother is too much on 40 no-load cars. When passing through very hard ground, he can even throw a cheek. Your grip is reduced. If there is a load (+300) it is ok but not necessary in winter conditions. Play 30-35 max.
| 08.05.2020 15:07 | # 5 |
Someone said at the gas station (your rims are 16) 40 goes to the ridden room :))) I have to take it to the tire man today.
| 08.05.2020 15:07 | # 6 |
I am also a 307 SW user. My tire size is 195/65/15 to be original. Tire pressures are 2.5 bar behind them 2.5 without load. Since 1 bar is approximately 14.5 psi, you need to blow 36 psi of air. |
| 08.05.2020 15:07 | # 7 |
I did not fully understand my rim 16 inch rim but I am a new car user so I am a beginner :)
| 08.05.2020 15:07 | # 8 |
[QUOTE = oguz6578] 16 inch rim on you I did not fully understand but I am a new user of the bidet, I am novice:) [/ QUOTE] The last figure in the dimensions 195/65/15 gives the canteen cap. So it's a 15 inch wheel. |
| 08.05.2020 15:07 | # 9 |
Ideal for a 16 inch rim is 34 psi or higher. 30-32 remains low. Also, give up the pressure of reducing the pressure of the tires in the winter. Many advanced driving experts say this is useless, even harmful, but we still recommend it to each other. oguz6578 vehicle should be writing on the driver's side the tire pressure measurements in bars. If you multiply the value there by 14.5, you will find out how many prints you need.
| 08.05.2020 15:07 | # 10 |
Thanks a lot badires bro .... I write again when there is a problem, I am new here in the car, thank you very much for the answers in the driving .... (what are you causing nitro gas event?)
| 08.05.2020 15:07 | # 11 |
[QUOTE = oguz6578] Thanks a lot badires bro .... I write here again when there is a problem. A discussion on the sub-topic was made immediately. http://forum.peugeotturkey.com/forum_posts.asp?tıd=13072&title=lastiklere-nitrojen-gaz |
