thermostat problem
08.05.2020 14:59 # 1
Onur
today I changed the thermostat of the vehicle. In the past, the temperature between 80-90 was only going up to 90 on the ramp, now it is 90 to 90 minutes with the new thermostat.
08.05.2020 14:59 # 2
How is the tactical thermostat original or a different product? can it be different?
08.05.2020 14:59 # 3
Onur
cem hocam original thermostat was installed in the authorized service, the old thermostat was worn out a lot, and I do not know if the original one is in my hand, I do not know if there is a problem in the old thermostat. valle
08.05.2020 14:59 # 4
I do not have detailed information about the 206's fan systems. How many fans do you have to look at? For example, my own vehicle runs at 97C and the fan stops at 90C. Since I bought the vehicle. I changed it at the thermostat, I changed it at the same time.
08.05.2020 14:59 # 5
okan77
Antifreeze may have an effect.
08.05.2020 14:59 # 6
I think the antifreeze has no effect. Because the liquid we call anti-freeze only prevents freezing. it does not have a heat related effect. For example, I think that the fan opening at 90 will not create a situation like the fan opening at 100.
08.05.2020 14:59 # 7
okan77
in http://forum.peugeotturkey.com/forum_posts.asp?tıd=9402&title=206-xt-hareret-srekli-90n-zer
For information purposes ....
08.05.2020 14:59 # 8
okan77
the http://forum.peugeotturkey.com/forum_posts.asp?tıd=7843&title=206-soutma-su
08.05.2020 14:59 # 9
ali oncu
Honor I have 206 changed in antifreeze during maintenance, the temperature is above normal. 206 thermostats turn on fans at 92 degrees. but mine now goes back to old times. He watches between 80 and 90 again. I think antifreeze will have an effect
