sports bow fitting
08.05.2020 15:05 # 1
10RS935
slm friends I have a red 2004 206 I bought a 5 cm sports bow, I went to the masters but I couldn't get a bit of it.
08.05.2020 15:05 # 2
xdesign
What the hell is it? Helix by name
08.05.2020 15:05 # 3
Muhammet CAKIR
You are well, go to the master, brother, you don't know the guy, he also wants to charge you :) :) Also, the car sits better on the road because the car is closer to the ground: D makes the car fly higher than the ground. Muhammet ÇAKIR 2011-02-11 17:44:04
08.05.2020 15:05 # 4
10RS935
hmm, I understood that there will be arcs, when you know me, I will remove the springs on the top and wear it
08.05.2020 15:05 # 5
metin
the master will not be correct without the shock absorber.
If you lower it by 3.5 cm, you only need to change the spring, but if you will lower it more, you need to change the shock absorbers.
suspension is very important. God bless bad things can happen.
08.05.2020 15:05 # 6
10RS935
What I know is the springs I bought 3.5 but I do not know exactly.
08.05.2020 15:05 # 7
xdesign
Metin has no exact standard. Due to the balance between torsion and cone, categorical products have been created in the world as 3.5 cm and 4 cm and 5 cm.
08.05.2020 15:05 # 8
10RS935
bro, xdesign bro, do i appreciate what do you say? By the way, how do I know how many cm I have?
08.05.2020 15:05 # 9
xdesign
Sister 3.5, you put it 4 cm and 4, you put it 3. You get him set up. But if you have it, you can also adjust the torsion. Since you are subjected to appreciation. But keep your shock absorbers. Up negotiate. Don't make your original way in any way. Let's see if you put your photos.
08.05.2020 15:05 # 10
d3Li
No need to change the amorsitor in 5 cm, the master wanted to sell you a blade amoritor.
08.05.2020 15:05 # 11
klemann
I don't need a shock absorber replacement;)
08.05.2020 15:05 # 12
10RS935
yeah thank you guys i will make photos tomorrow
08.05.2020 15:05 # 13
10RS935
friends, this is me, I made little lights led, made the headlights angel, and I will wear sports bows and make you go crazy.
08.05.2020 15:05 # 14
10RS935
Uploaded with ImageShack.us
08.05.2020 15:05 # 15
Unhook the nickels without any paint, then paint the door handles and laths, including the bumper, on the body color.
08.05.2020 15:05 # 16
http://forum.peugeotturkey.com/forum_posts.asp?tıd=12536
Let's examine this issue.
08.05.2020 15:05 # 17
d3Li
[QUOTE = 10RS935]
Is this post stuck on the carpet?
