My voice is now too loud (updated)
08.05.2020 15:45 # 1
TarkanBassoy
Hello friends, I will probably make a sound system for the car tomorrow. I have a budget of 750 liras. As I mentioned in the previous subject, I will use the original CD tape. I am thinking of installing 1000 watt woofers and amps in 4 components 1 and I thought all of them were jbl brand. Do I get a satisfactory sound from such a system? What kind of system do you suggest? Where can I get this job done properly and properly in Ankara? The original tape of the vehicle is the same as the 308s, and I expect an opinion about efficiency from those who connect the system to this tape.
Before the last update, my car had a 500watt oval pionner speakers in the pendulum, they were gone instead, the 16cm component came to the rear doors, the sound was cleaner and more beautiful. Alkış
Current system:
16.5 cm kicker in front DS DS 650.2 component
16.5 cm kicker DS 650.2 component at the back
JBL 1000watt 30 cm cabinet bass
DD audio c4b 4 channel amp
Pionner 2350UB main unit
tarkanbaşsoy 2011-09-15 23:42:36
08.05.2020 15:45 # 2
jbl you get a nice brand efficiency
respects
08.05.2020 15:45 # 3
d3n1s
As far as I know, there is no amp output on the original tape, I don't think it will take much efficiency, if you buy a tape at a later time, then you will set up a system like your head. As I said, don't expect much efficiency from the original tape.
08.05.2020 15:45 # 4
[QUOTE = d3n1s] As far as I know, there is no amp output on the original tape, I don't think it will get much efficiency, if you take the tape at a later time, then you will set up a system like your head. As I said, don't expect much efficiency from the original tape [/ QUOTE]
+ 999 Thumbs Up
08.05.2020 15:45 # 5
TarkanBassoy
my http://forum.peugeotturkey.com/forum_posts.asp?tıd=15716&title=307-cd-alar-deii
As I have stated on this matter, I have to use the original tape. Ağlama
08.05.2020 15:45 # 6
d3n1s
manager, I will give you a nice suggestion, I told you about the link you gave yourself at the top, remove the cd changer in your car, replace it with a beautiful tape, keep the original tape of your car on top, you will connect the new tape to the cd changer port of the original tape, so you check both the original tape you can control the transactions and you set up the system. It will be an eye-pleasing process, two tapes under it but the most reasonable solution looks like this d3n1s 2011-07-04 11:17:50
08.05.2020 15:45 # 7
sercinho
[QUOTE = d3n1s] manager will have a nice suggestion for you, I told you about the link you gave yourself at the top, remove the cd changer in your car, replace it with a nice tape, keep the original tape of your car on top, you will connect the new tape to the cd changer port of the original tape, so you can both control the processes you control from the original tape and also set up the system. It will be an eye-pleasing process, two tapes under it but the most reasonable solution looks like this [/ QUOTE]
tarkan, you can do it in an application, if you want, the tape will stop, you can go from there to the menu again, or there is an apparatus in the sound systems. If you have not tried to try a tape recorder, you will get a tape recorder.
08.05.2020 15:45 # 8
TarkanBassoy
According to the view, I will first link to the original tape because I cannot separate more butce. If I do not get the efficiency I want, I will get a tape recorder system in a couple of months. So, who should have this work done in Ankara? Is there any place that you can recommend both in terms of price and proper work? (I am sorry for spelling now, the characters are a bit skinny because I write on the phone)
08.05.2020 15:45 # 9
pionner tape 150 tl zero
jbl container bass 130 tl zero
xetec 4 channel amp 150 tl zero
amp cables 50 tl zero
jblo midi team 110 tl zero
590 tl in total;)
08.05.2020 15:45 # 10
alisuat
pioneer go to mehmet, goose, talk, talk at a price in black bean.
I suggest you put the cd changer out of the tape instead of a pioneer 2200. It has around 200 TL usb aux input.
jbl gto 530 is 150 TL on front doors
You have 4 channels of amplifier, mounting etc. Amount between 200-250.
Around 150 bass with jbl cabin in a row.
750 TL in total;)
08.05.2020 15:45 # 11
TarkanBassoy
Aren't we going to put a column behind, so guys, everyone just wrote componet in front.
08.05.2020 15:45 # 12
sercinho
tarkan erhan there is a place your brother knows in kecioren he will help you
08.05.2020 15:45 # 13
Yes, Tarkan will gladly help you, brother. I have a friend doing this and all the materials you have are professional materials. If you want, let me see you, I'm sure you'll be satisfied. At least you know the system in my vehicle.
08.05.2020 15:45 # 14
TarkanBassoy
Thanks for your help, friends, I went to the place where Erhan recommended his brother and made the sound system. A price of 950 lira came out, but I thought it was nice to be silent. My voice is too loud now Sırıtma .
I noticed when I was approaching the garage a little while ago, my parking sensor is not sounding, which is why does it have anything to do with the sound system? I feel so depressed, we stopped Ağlama
08.05.2020 15:45 # 15
sercinho
Good luck my brother, what do you get? Does the original tape stand as a brand. The parking sensor has a little speaker in the trunk under the tap at the back.
08.05.2020 15:45 # 16
Good luck, my brother, listen to you as much as you can. Sırıtma
08.05.2020 15:45 # 17
TarkanBassoy
Thanks Osman brother, Sercan. Wives Dil Çıkarma . Sercan brother is the original tape stands, changer came instead of pionner tape. Front kicker componentet 1000watt jbl woofwer and audio system amplifier in the back. As the back doors are empty, since I can't afford the money, I will have a 13 cm infinity column in the back when I get some budget back. I hope it is easy to handle, the parking sensor is actually working, there are image approach lines on the screen but no sound. It also does not work when the sound is gone. I have to get it fixed so I got used to it that today I was hitting 2 times, as the skin is coming back, I have no need to look back because I have been using the sensor for years. Dil Çıkarma I am very busy going out of the city for the next few days. I'm going to go back to the parking sensor where I got the system on Saturday and tell the parking sensor. My guess is that the cable was damaged when I removed the tape.
Separately, Erhan, thank you very much to my brother, he was very interested, he called several times during the day, asked the situation in the morning, he helped me by calling the tape recorder before I left.
hardtouch 2011-07-06 00:05:54
08.05.2020 15:45 # 18
sercinho
[QUOTE = hardtouch]
Don't worry, my brother will recover, there is a small problem with a big possibility.
08.05.2020 15:45 # 19
ErcaNKarsI
good luck :) for those who are not :)
08.05.2020 15:45 # 20
TarkanBassoy
Now my voice is getting louder :)). Now I made a couple of updates, 500 watt pionner was installed on the rear pandizos, the sound was adjusted to my taste, now it became more enjoyable :)
Page : / 2
