LOCKED DIFFERENTIAL
08.05.2020 13:56 # 1
LOCKED DIFFERENTIAL TECHNICAL SPECIFICATIONS KEY DESCRIPTION 1 Diff cage 1 2 Diff cage insert 1 3 Wavy washer 1 per side 4 Thrust washer-cage side 1 5 Belville preload plate 1 per side 6 Externally toothed plate 3 gear side & 2 cage side 7 Internally toothed plate 3 gear side & 2 cage side 8 Planet driver 1 per side 9 Cross pin 2 10 Side gear - cage side (ext. For std shaft) 11 Planet pinion 4 12 Thrust washer - cover side 1 13 End cover with integral ring gear in place of production press / glued fit gear 14 Side gear - cover side
08.05.2020 13:56 # 2
You can read http://forum.peugeotturkey.com/forum_posts.asp?TID=436 Turkish narration here, friends.
