If the timing sent setting is wrong
08.05.2020 15:26 # 1
bestfear
How to understand if the sente setting is not done correctly after friends timing set change
After removing my vehicle timing. the valves have changed. Car repair was maintained. It was 750 kms, the car's flight was good, but the sound of the car was a little different, it was quieter before. Could they have jumped on the sentence ... how to understand ...
08.05.2020 15:26 # 2
monur
We are able to do 750 km with an engine that jumped into the fog. Either the valves or the cups, the operation of an engine with a malfunction of Sente will be excessive knock.
Edit: I wrote 75 instead of 750.
monir 2011-05-20 09:58:57
08.05.2020 15:26 # 3
Our honor brother did not say right.
You already said the food check is beautiful. If its synthesis is broken, it won't work properly anyway ...
08.05.2020 15:26 # 4
fahrikem
If the tuner runs out of the sentence setting, you will know immediately that the engine distributes valves etc. If the master changes the alternator belt with Triger, that sound may be coming from the belt.
08.05.2020 15:26 # 5
mon
You have changed the valves, the valves of the valve did not get used to the sound. In the sente setting, a single tooth jump of the trigger causes the motor not to start.
08.05.2020 15:26 # 6
bestfear
Thank you guys, you sprinkled water in me ...
08.05.2020 15:26 # 7
ose
[QUOTE = mon] valves have changed. The valves of the valve did not get used to the sound. In the sente setting, a single tooth jump of the trigger causes the motor not to start.
the valves will get used to.
08.05.2020 15:26 # 8
ismail ozdemir
I changed the triger too, it was 10-15 days, the sound of the car is not as old as it is but there is no problem and as I follow it improves day by day.
08.05.2020 15:26 # 9
I was back on the post in this regard .. When I took the car from God to the berke, they noticed .. I have a given loyalty ..
08.05.2020 15:26 # 10
scorpions_64
[QUOTE = is bestfe]
After removing my vehicle timing. the valves have changed. Car repair was maintained. It was 750 kms, the car's flight was good but the sound of the car was a little different, it was quieter than before .. I wonder if they might have jumped into the sentence ... how to understand ... [/ QUOTE]
buddy how much have you changed the valves?
08.05.2020 15:26 # 11
azdek
It is true that I just changed the new triger at the authorized service.
08.05.2020 15:26 # 12
bestfear
[QUOTE = scorpions_64] [QUOTE = bestfear]
You can look at the subject covered here ...
