Heater Problem
08.05.2020 21:03 # 1
Heredot
Friends first hello 2004 1.4 HDI 307 I have my car does not blow hot air, it looks hot when I look at the pipes under the steering wheel and it is not even faulty. thanks in advance
08.05.2020 21:03 # 2
There are a few reasons, as you said, the possibility of making an air as you said, there is a piece on the hoses entering the vehicle in the engine part, such as a cap in the tire valves, you can get the air from there. Secondly, the flap that turns hot and cold may be defective.
08.05.2020 21:03 # 3
Heredot
[QUOTE = sonerkyl] There are a few reasons my teacher has the possibility of making an air as you said, there is a piece on the hoses entering the vehicle in the engine part, like a cap in the tire valves, you can get the air from there. Secondly, the flap that turns hot and cold may be defective.
Thank you, teacher, I hope I will try it, I hope it will be successful.
08.05.2020 21:03 # 4
Heredot
[QUOTE = Heredot] [QUOTE = sonerkyl] There are a few reasons, the possibility of making an air like you said, there is a piece like a cap on the rubber valves on the hoses entering the vehicle in the engine part. Secondly, the flap that turns hot and cold may be defective.
I got the air again it didn't work I wonder why else
