Heater does not heat?
08.05.2020 21:05 # 1
lilokan
friends overheat over 90. Actually, there is a normal temperature when I turn the heater on the 2nd setting. When I bring it to 3rd degree, the temperature drops a little. In the 4th degree, it falls completely and blows warm. What do you think is the solution ??
08.05.2020 21:05 # 2
you probably need to get the air of the teacher. Is it digital or analog? sonerkyl 2018-11-26 08:56:04
08.05.2020 21:05 # 3
lilokan
[QUOTE = sonerkyl] you probably need to get the air of the teacher. Is it digital or analog? [/ QUOTE]
Anolog teacher. Where and how can I get the weather? Or can I do this?
08.05.2020 21:05 # 4
You can get detailed explanations in the subject that I have given my teacher link. There is a chronic problem in digital ones such as stripping gears for analog or digital reason.
08.05.2020 21:05 # 5
lilokan
You can get [QUOTE = sonerkyl]. There is a chronic problem in digital ones such as stripping gears for analog or digital reason.
Thank you very much, teacher, I hope I will handle it at a time. God bless you
08.05.2020 21:05 # 6
You're welcome, teacher.
08.05.2020 21:05 # 7
lilokan
[QUOTE = sonerkyl] Thank you, my teacher. [/ QUOTE] My teacher dropped the air valve while the master opened it. Then we couldn't find the valve. We poured water or something to fall down, we found the valve with the bins, I went home. Bikac hour after I got into the car, the car does not work. Mars is pressing but not working. I waited for 10 minutes and got pressed again. I went where I was going. Then I pressed Marsa to come home again, no problem again. After 2-3 hours, I got into the car again, pressing the mara, but still not working. I'm running, no car is not working. What could be the problem?
08.05.2020 21:05 # 8
lilokan
Meanwhile, the vehicle is working with LPG. Since I always use it in gasoline, there is no lgp in action. When I hold down the lpg button, the car buys, then it throws it back into gasoline and stops because it is not lgp. Could the gas pump role or something be malfunctioning because they touched the engine with water? They did not put any parts in order to reach that valve, and when he moved his arm or something around with that narrow field, he might have been giving them some damage or. I will get crazy
08.05.2020 21:05 # 9
AVORAN
The biggest reason that your heat exchanger does not heat as before may be " CHALLENGER PIPE CONSTANCE ". Remove the pipe ends, thread the other end of the hose from the fountain into one of these ends. Clean the sludge (black - gray) pulp blocking the inside of the heatpipe. Your stay will work as the first day. (You should follow this process every 6-7 years and keep your pipes clean)
08.05.2020 21:05 # 10
lilokan
thanks my teacher we took care of it
08.05.2020 21:05 # 11
[QUOTE = lilokan] teacher, meanwhile, the vehicle is working with lpg. Since I always use it in gasoline, there is no lgp in action. When I hold down the lpg button, the car buys, then it throws it back into gasoline and stops because it is not lgp. Could the gas pump role or something be malfunctioning because they touched the engine with water? They did not put any parts in order to reach that valve, and when he moved his arm or something around with that narrow field, he might have been giving them some damage or. I'm going to go crazy [/ QUOTE]
Strange situation, my teacher.
08.05.2020 21:05 # 12
lilokan
[QUOTE = sonerkyl] [QUOTE = lilokan] teacher, meanwhile, the vehicle is working with lpg. Since I always use it in gasoline, there is no lgp in action. When I hold down the lpg button, the car buys, then it throws it back into gasoline and stops because it is not lgp. Could the gas pump role or something be malfunctioning because they touched the engine with water? They did not put any parts in order to reach that valve, and when he moved his arm or something around with that narrow field, he might have been giving them some damage or. I'm going to go crazy [/ QUOTE]
[/ QUOTE] no problem, the road computer was already showing 50km. Do not pressurize due to lack of gasoline vehicle does not work from it Big smile
08.05.2020 21:05 # 13
that means he's having his last days in the gas pump Big smile
08.05.2020 21:05 # 14
lilokan
[QUOTE = sonerkyl] means he's having his last days on the gas pump Big smile [/ QUOTE]
I think there is no sound in the pump, hodja. Because the trick is pretty normal, it's not the question. Big smile
