CATALYST CLEAN ???
08.05.2020 18:48 # 1
ENES 307 HDI
I would appreciate if the competent, knowledgeable friends can help, because friends save cleaning because the catalyst prices are too high ...
08.05.2020 18:48 # 2
suppor
I wonder if we could empty the pole
08.05.2020 18:48 # 3
ENES 307 HDI
I don't know, but are there any places that do this cleaning in Kocaeli and Istanbul (Anatolian side)
08.05.2020 18:48 # 4
outlaw
I HAVE NEVER HAD THE CLEANING, BUT I HIDEN THAT IT HAS BEEN EMPTYED.
THE CATALIZER WITH THE IDENTIFICATED STAY ONLY FOR THE VISA TO PASS VISA.
Does not separate poisonous gases ...
08.05.2020 18:48 # 5
suppor
I emptied me to give money to those who are being followed free of charge from the European countries.
08.05.2020 18:48 # 6
ilyas
there is a floor cleaning place on the european side. Sirinevler is also called the exhaust market. If there is no show, you can find the exit or you can empty it and continue without the illumination light with the sensor misleading.
08.05.2020 18:48 # 7
DgNTsN
Substances such as Platinum, Rhodium, Palladium in the catalyst eliminate toxic gases by chemical reaction. Over time, a new product is formed in the chemical reaction and over time it loses its substance property, or rather the reaction coefficient. It's like melting ice. This tool is expensive because of the ingredients it contains.
as a result, it cannot be cleaned. If it is left, it removes the tertiary substance formed as a result of the reaction in it, if it is left.
that is, emptying a finished converter and emptying it provides the same gain. however, it does not return.
dgntsn 2014-09-17 17:32:38
08.05.2020 18:48 # 8
Efe-Pojo
it is cleaned, if it is clogged, it is kept in a special solution for a very long time, and when it is completely dry, it is replaced again. But if cracks have formed or started to fall off, cleaning will not work.
08.05.2020 18:48 # 9
ENES 307 HDI
Thank you for your useful information. They said that my car was throwing black smoke from the catalyst, they said clean it or something again in this forum. I will be glad if you help me ...
08.05.2020 18:48 # 10
Ali1905
If your vehicle is blowing black smoke, have Turbo first, injectors, then Egr and catalyst.
08.05.2020 18:48 # 11
DgNTsN
my buddy discharges the catalyst like all pejoggers did, cancel egr. these devices exist to pollute the air. but if they no longer do their job, you will pollute the air more. as a result, the car relaxes.
08.05.2020 18:48 # 12
ENES 307 HDI
Turbo and injectors changed to zero. Egr and catalyst remained only. They say the fuel will increase if I cancel the catalyst, right?
08.05.2020 18:48 # 13
herry
dude I used the search button of the forum for you, I found some useful information. I recommend you to read.
in http://forum.peugeotturkey.com/forum_posts.asp?tıd=33189&kw=kataliz%f6r&title=katalitik-konvertor-hakk
I http://forum.peugeotturkey.com/forum_posts.asp?tıd=22226&kw=kataliz%f6r&title=katalitik-konvertor-dagil
the http://forum.peugeotturkey.com/forum_posts.asp?tıd=25834&kw=kataliz%f6r&title=206-kat-iptal
http://forum.peugeotturkey.com/forum_posts.asp?tıd=25983&kw=kataliz%f6r&title=kara-du financing
http://forum.peugeotturkey.com/forum_posts.asp?tıd=25363&kw=kataliz%f6r&title=egzoz-ve-kataliz is
Thumbs Up
08.05.2020 18:48 # 14
ENES 307 HDI
[QUOTE = herry] buddy I used the search button of the forum for you, I found useful information. I recommend you to read.
Thumbs Up
[/ QUOTE] Thank you very much
