ABS and Fuel
08.05.2020 20:35 # 1
HD494
Sa friends, I would be glad if you help me with two questions
1- 2001 1.4 206 XR gasoline automatic I have, what is the probability that the vehicle will not have ABS? I showed that I had a problem with the brakes, said the master, there is no ABS. Doesn't these models have ABS?
2- It burns 55 cents per km, I expected it to burn a lot since gasoline is automatic, but is that a bit too much?
08.05.2020 20:35 # 2
Welcome to ace.
If we come to the problem, the autos will usually have abs in all of them. as the picture in the link
2-Unfortunately, many of the old-fashioned shamakas are on the long road to see the gold they have consumption around. heleki is like a lpg is a must in the city in istanbul.
08.05.2020 20:35 # 3
HD494
sonerkyl, bye thanks
Thank you very much in the answer you gave.
One more question, I'm very unsure about the Lpg. Some say the plug-in damages the engine, and some say that the fuel will be cut in half. I can not decide what to do. Do you have any idea?
08.05.2020 20:35 # 4
RP393
Hodja, calculate your fuel in liters. It should go an average of 10 km with 1 lt.
The penny account is now misleading. Gasoline was 5.5. It used to be 20-25 cents.
08.05.2020 20:35 # 5
HD494
Thanks RP393
08.05.2020 20:35 # 6
talip206
Mine doesn't have automatic abs either. If there is abs contact, the abs light will flash when the contact is open. Even if there are 55 cents in gas Prices have risen a lot. Factory data is already 10 liters per 100 km in the city. I appreciate the lpg without thinking I am very pleased. Burns as little as manual on long road
08.05.2020 20:35 # 7
HD494
Thanks suitor,
