A Simple Two Questions
08.05.2020 17:58 # 1
NidderuN
First of all, I would like to state that I am very inexperienced and the subject is not opened for wave purposes.
My questions are,
1-307, how can I wash my black car without scratching, what should I use with foamy water, brush or spongy and how do I do that.
2-The vehicle has a cruise control system but how do I know if it is active or not?
3-In general, what would you suggest to use the vehicle clean and well?
DN: Vehicle 2008 model, at 34 thousand km.
08.05.2020 17:58 # 2
Alicilik
Hodja is written on an article by himself.
You can look at this header for washing ..
http://forum.peugeotturkey.com/forum_posts.asp?tıd=25505&title=karcher-basnl-ykama-geldiden was
Even if the car is scrap, I don't use brush-synthetic sponge. worm gloves can be used.
When it is very muddy, first soften it with water then foam-rinse-dry.
Rinsing is very important. If the vehicle remains unable to stay, we will take a cloth to dry and draw the car beautifully.
You need to be in 4th gear for the cruise to go into 4th gear and press the plus or minus one becomes active.
To keep it clean,
Rubber mat
A non-glossy protective for the front chest.
-Detailed cleaning of floors and protection on top
-To protect the vehicle with a good wax polish and then protection.
08.05.2020 17:58 # 3
NidderuN
where can I get a worm glove, a rubber mat, a non-glossy protective for the front chest, what are the prices?
How do I make the foam in the foam-rinse-dry event? Don't rush over with rinsing water? How do you need to do the drying with something, I think you say no diapers?
How do I clean the flooring in detail, what protection can be put on it?
08.05.2020 17:58 # 4
Alicilik
Most of the products you want to buy are available in building markets, but if you want more options, you should look at sites like Hepsiburada.
You can look at the mats suitable for your vehicle. I would recommend Automix odorless rubber mats that are very useful but thin. They are drilled in 2-3 years.
Turtle wax F21 for chest in the market from 15 to 23tl
You need to use a machine for foam rinsing and drying processes. There is a pressure washing machine at prices starting from 150. I would like to do it for hobby purposes. If you say no materialism too;
-Filter washing bucket (2 pieces)
-Worm and wash gloves
Polished shampoo (polish softens)
-Dry towel (autocsi 50 * 70 towel is highly recommended)
-It can be polished quickly while drying on demand (leaving a nice shine) (sonax recommended)
- wax pad
If your vehicle is extremely dirty, go to a petrol station and throw away the dirt with pressurized water from above. Then, I add more scales of shampoos to the buckets I mentioned, the first one to a lesser scale and the other to the foam. Lower the dirty vehicle slightly and lightly with the fewer ones (the pressurized machine cannot remove the dirt that adheres to the surface).
Then wash with a lot of other shampoo (not excessive, then rinse will be troubling) and foamy foamy gently.
rinse by ripping pure water if possible
If you bought a quick polish before you start drying, divide the tool into areas and you will see that the water on the surface flies quickly after you spray the polish lightly on a region and spread it with a pad, so wipe it with a cloth or the stain will remain.
It will then look great. These are very burdensome and tiring, but I willingly and lovingly devote one day a week to it when the house bark is not a child: D I'm intense my car: D
08.05.2020 17:58 # 5
NidderuN
Hodja, you told me well, he did not look good, you should look at the car in black, but in winter, let me take it towards spring. I have a question for this machine. Finally, can you give information about the brand model and where can I buy it?
08.05.2020 17:58 # 6
[QUOTE = nidder a]
My questions are,
Hi;
In my opinion, sponge, brush, cloth all draw the car, because when you use the wet powder, you can clean it by pressing it lightly. This causes dust to scratch the car. Again, in my opinion, the best to wash the car is Water + Foam water again, and this process is applied several times (I might be wrong)
08.05.2020 17:58 # 7
Alicilik
[QUOTE = dogan106]
Hi;
I explained the drawing event elsewhere. Drawing the paint of the vehicle is not so easy. The cloth does not scratch a sponge or brush. These are dust or particles on the vehicle or on these materials.
A soft surface clean oven will never scratch a clean car all day. But if there is dirt in the car or brush, this definitely plays a role in drawing. You don't need a big piece to draw it. The reason for radial scratches seen in solar reflections is small materials.
So the healthiest method is to clean with two buckets (there will be a strainer at the bottom of the buckets). If the vehicle is very muddy, it should be washed with pressurized water starting from below. Then double kkova foam should be washed.
A separate cloth should be used on the surface of the vehicle and the mirror separately.
08.05.2020 17:58 # 8
error
if possible, do not lay the vehicle at the door under the sun, even this will extend the life of the paint torpedo and flooring.
08.05.2020 17:58 # 9
NidderuN
@Alicilik
Hodja, especially you gave very good information, thank you.
Now can you give me a list that I can understand, I will go and get what you wrote. I saw a set for 10 TL in Bim yesterday and bought it as cheap (Auto Shampoo, Rim, Inner Polish, Perfume). Today I tried to do something with a brush, 2 buckets of water, 4 cloths, but it sucks. He never got inside.
Best of all, let me give the master a nice list like this, let me get a zero from your bucket to the brush. I also did not understand whether it was very difficult to wash the ceiling or something, using a bucket or a brush, or brush or something ...
08.05.2020 17:58 # 10
NidderuN
up
08.05.2020 17:58 # 11
Alicilik
[QUOTE = Buying] Many of the products you want to buy are available in building markets, but if you want more options, you should look at sites like Hepsiburada.
- wax pad
08.05.2020 17:58 # 12
mermi6458
Ali brother, you are sick of this style of narration that is not known to end, you have a light.
