Nissan 370Z 40th Anniversary - 2010
Forum Adı: Haberler
Forum Tanımlaması: Otomobil, Teknoloji, Spor ve diğer tüm konular hakkında güncel haberler
URL: https://forum.peugeotturkey.com/forum_posts.asp?TID=7402
Tarih: 30 Eylül 2025 Saat 18:44
Konu: Nissan 370Z 40th Anniversary - 2010
Mesajı Yazan: Kifanhom
Mesaj Tarihi: 07 Ocak 2010 Saat 23:01
Engine Location Front
Drive Type Rear Wheel
Body / Chassis Unibody
Production Years for Series 2008 -
Weight 3426 lbs | 1554 kg
MPG City 18
MPG Highway 25
Introduced At 2008 LA Auto Show
Performance
Coefficient of Drag 0.33
Engine
Engine Configuration V
Cylinders 6
Engine VQ37VHR
Aspiration/Induction Normal
Displacement 3.70 L | 225.8 cu in. | 3700.9 cc.
Valves 24 valves.
4 valves per cylinder.
Valvetrain DOHC
Horsepower 332.00 BHP (244.4 KW) @ 7000.00 RPM
Torque 270.00 Ft-Lbs (366.1 NM) @ 5200.00 RPM
HP to Weight Ratio 10.3 LB / HP
HP / Liter 89.7 BHP / Liter
Redline 7500
Compression Ratio 11:1
Fuel Feed Fuel Injected
Sequential Electronic Multi-port Fuel Injection
Block Aluminum
Head Aluminum
Standard Transmission
Gears 7
Transmission Automatic
Final Drive 3.692
Dimensions
Cargo Volume 4.20 cu. ft.
Passenger Volume 52.301 cu. ft.
Interior Volume 56.501 cu. ft.
Fuel Capacity 19.0 Gal
Seating Capacity 2
Doors 2
Exterior
Length 167.201 in | 4246.9 mm.
Width 72.801 in | 1849.1 mm.
Height 52.201 in | 1325.9 mm.
Wheelbase 100.401 in | 2550.2 mm.
Front Track 61.001 in | 1549.4 mm.
Rear Track 62.801 in | 1595.1 mm.
Interior
Front Headroom 38.701 in | 983 mm.
Front Legroom 42.901 in | 1089.7 mm.
Front Hip Room 54.61 in | 1387.1 mm.
Front Shoulder Room 54.401 in | 1381.8 mm.
Suspension
Suspension Front : Double wishbone aluminum suspension
Rear : Independent multi-link aluminum suspension
Steering
Rack and Pinion with Power Assist
Steering Overall Ratio 13.5:1
Turns lock to lock 2.70
Turning Circle 32.801 ft
Brakes
Front Brakes Fixed 4-piston
Rear Brakes 2-piston
Front Brake Size 12.601 in | 320.1 mm.
Rear Brake Size 12.601 in | 320.1 mm.
Tires / Wheels
Tires Bridgestone Potenza RE050A
Wheels 19-inch super lightweight forged alloy
Spare Tire Steel, T145/80D17
http://img177.imageshack.us/i/75505690.jpg/"> http://g.imageshack.us/img177/75505690.jpg/1/">
http://img213.imageshack.us/i/52149002.jpg/"> http://g.imageshack.us/img213/52149002.jpg/1/">
http://img690.imageshack.us/i/18970741.jpg/"> http://g.imageshack.us/img690/18970741.jpg/1/">
http://img11.imageshack.us/i/83868563.jpg/"> http://g.imageshack.us/img11/83868563.jpg/1/">
fn2
http://img341.imageshack.us/i/unutmayinizq.gif/" rel="nofollow">
Mesajı Yazan: MirakGTI
Mesaj Tarihi: 07 Ocak 2010 Saat 23:03
paylaşım için teşekkürler.
deli makine..
www.PeugeotTurkiye.Com
"Tuning Sitesi Değil Marka Sitesidir"
http://forum.peugeotturkey.com/forum_posts.asp?TID=8290 - Forum kurallarını okumak için tıklayınız!
Mesajı Yazan: GökhaN
Mesaj Tarihi: 07 Ocak 2010 Saat 23:11
insan işi değil ya Ouch
Mesaj Tarihi: 07 Ocak 2010 Saat 23:29
hakkaten deli makine
fn2
Mesajı Yazan: Aytaç
Mesaj Tarihi: 07 Ocak 2010 Saat 23:41
Ucuk Kaçık Bir Makine..
