ARKA STOP LAMBALARI
Forum Adı: 206
URL: https://forum.peugeotturkey.com/forum_posts.asp?TID=12941
Tarih: 04 Mayıs 2026 Saat 00:19
Konu: ARKA STOP LAMBALARI
Mesajı Yazan: albay32
Mesaj Tarihi: 17 Şubat 2011 Saat 10:02
ARKADAŞLAR BENİM 206 STOP LAMBALARI YANMIYOR FIRENE BASTIGIMDA 2 TARAFDA YANMIYOR SİGORTALARA BAKTIM SAĞLAM AMPÜLLERDE SAĞLAM ACABA NEREDEN KAYNAKLANIYOR SİGORTA TABLOSUNDA NUMARALAR VAR HER 1 SİGORTANIN YANIN DA ACABA ARKA FREN LAMBALARININ SİGORTA NUMARASI KAÇ ? YARDIMLARINIZ İÇİN ŞİMDİDEN TEŞEKKÜRLER ..
Mesaj Tarihi: 17 Şubat 2011 Saat 10:18
Thumbs Up
Mesajı Yazan: koliva
Mesaj Tarihi: 17 Şubat 2011 Saat 10:23
Asagidaki tabloya gore F11 ve F12 numarali sigortalar sag, sol ve ust fren lambalari icin.
28 fuse box in passenger compartment, without rear electric window (BFH28-1)
Fuses
Rating
Supply
Application
F1
Shunt
Ignition + ve
Pretensioner unit, front airbags, side air bags, BSI
F2
5A
Instrument panel
F3
FREE
F4
5A
BSI
F5
Free
F6
5A
+battery
ignition + ve
Engine management control unit, immobiliser
F7
Free
F8
10A
Coolant temperature unit, instrument panel, hazard warning, clock, multifunction display, courtesy lamp
F9
5A
BSI
F10
Free
F11
10A
Ignition + ve
Left brake light, third brake light
F12
10A
Right brake light
F13
+ battery
Free
F14
30A
Rear window power
F15
20A
Boot light, , tow-bar supply
F16
Free
F17
Free
F18
10A
Sidelamps +
Number plate light. Illumination: lighter, instrument panel, heater panel, radio, ashtray, transmission selector, switches, clock, multifunction display
F19
5A
Rear fog lamp
Rear fog lights
F20
Input/outlet
Free
F21
Free
F22
10A
Acc + ve
Glove box light, map reading lamp, courtesy lamp, clock or multifunction display, instrument panel, on-board navigation, rear window lift, rain sensor, charge warining lamp
F23A
20A
Acc + ve
Cigar lighter
F23B
20A
+ battery
Cigar lighter
F24A
15A
Acc + ve
Radio
F24B
15A
+ battery
Radio
F25
20A
Acc + ve
Front and rear windscreen wipers
F26
Free
F27
5A
Built-in system interface (BSI)
F28
Free
Mesaj Tarihi: 17 Şubat 2011 Saat 10:26
Birde sadece fren lambalari mi yanmiyor? Digerleri calisiyor mu?
Mesajı Yazan: peugeotefe
Mesaj Tarihi: 17 Şubat 2011 Saat 10:29
Fren pedalının altında müşir var ona baksanız daha iyi olur sigorta ile uğraşmayın
Mesaj Tarihi: 17 Şubat 2011 Saat 10:43
BÜTÜN IŞIKLAR YANIYOR SADECE FREN LAMBALARI YANMAYAN  FREEN MÜŞÜRÜNÜ GÖRDÜM NERESİNE BAKIYIM MÜŞÜRÜN?
Mesaj Tarihi: 17 Şubat 2011 Saat 10:45
Orjinalini yazan: albay32 albay32 Yazdı:
Kablolari gevsemis olabilir. Cikarip yeniden yerine takmayi deneyin.
Mesaj Tarihi: 17 Şubat 2011 Saat 11:40
teşekkürler koliva arkadaşım Thumbs Up
Mesajı Yazan: Dewil1606
Mesaj Tarihi: 10 Ekim 2014 Saat 13:54
Aksam patlak ampulu deyistireyim dedim
Benimde sol arka firen
Lambasiyla bagaj kapagindaki firen lambasi yanmiyor yardimci
Olursaniz sevinirim
Mesajı Yazan: okan77
Mesaj Tarihi: 10 Ekim 2014 Saat 16:44
Eğer 106 quıksılverlardaki gibi aynı ise müşür bazen yukarı kayabiliyor ve yanmıyor... Yuvası plastikti galiba yanlış hatırlıyor olabilirim... Ben arkasına kablo toplama cırtı ile destek yapıp sabitlemiştim zamanında...
Mesaj Tarihi: 10 Ekim 2014 Saat 20:40
Müşürü kontrol ettim onda bi sıkinti yok elektirikciye goturdum oda bulamadi sorunun nerden kaynaklandigini çaresiz bi durum yani
Mesajı Yazan: Mehmet Yamak
Mesaj Tarihi: 30 Kasım 2015 Saat 13:36
Sayın Arkadaşlar önce saygılar Benimde sizlerden bir isteğim olacak benim araç peugeot partner bunun arka fren lambaları yanmıyor Ama arka kapının üstündeki yanıyor bu neden olabilir saygılar kolay gelsin
Mesajı Yazan: sonerkyl
Mesaj Tarihi: 30 Kasım 2015 Saat 16:42
Orjinalini yazan: Mehmet Yamak Mehmet Yamak Yazdı:
Öncelikle hoşgeldiniz, daha iyi yardım alabilmek için;
Yeni üyeliğini tamamlamış ve foruma girmiş üyelerimiz, "Üyelerimizi Tanıyalım" başlığı altında lütfen yeni konu açarak kendinizi tanıtınız, Tüm bilgileri eksiksiz doldurmanız sizi daha iyi tanımamız açısından bizlere yardımcı olacaktır, Bilginize...
Tanıtma Konusu Açmak İçin Lütfen;
Bu Linke Tıklayın: http://forum.peugeotturkey.com/new_topic_form.asp?FID=22" rel="nofollow - http://forum.peugeotturkey.com/new_topic_form.asp?FID=22
1.- Adınız, soyadınız:
2.- Yaşınız:
3.- Aracınız (Markası, modeli):
4.- Hobileriniz:
5.- Mesleğiniz:
6.- Siteyi nereden duydunuz:
7.- Kan Grubunuz:
8.- Burcunuz:
9.- Taraftarı olduğunuz takım:
10.- Hangi ilçe yada İldesiniz:
11.- Msn adresiniz:
İlginiz için teşekkür ederiz.
Peugeot Türkiye Fun Club Yönetimi
http://www.peugeotturkey.com/" rel="nofollow - www.peugeotturkey.com  &  http://www.peugeotturkiye.com/" rel="nofollow - www.peugeotturkiye.com
