Peugeot 106, 306, 406, 605 ABS ECU Hata Kodları.
Forum Adı: Yararlı Dökümanları
Forum Tanımlaması: Modifiye ve Tuning adına yararlı bilgiler
URL: https://forum.peugeotturkey.com/forum_posts.asp?TID=10603
Tarih: 02 Mayıs 2026 Saat 18:29
Konu: Peugeot 106, 306, 406, 605 ABS ECU Hata Kodları.
Mesajı Yazan: rifatseker
Mesaj Tarihi: 07 Eylül 2010 Saat 17:27
Alıntıdır.
PEUGEOT 106 1996-97 Hata kodları.
Fault code    Fault location
015Z     The system relay.
018Z     Rotors on the wheel speed sensor.
024Z     Rear left wheel speed sensor.
025Z     Front right wheel speed sensor.
031Z     Rear right wheel speed sensor.
032Z     Front left wheel speed sensor.
033Z     The signal of the wheel speed sensors.
053Z     The pump motor
055Z     ECU
057Z     The battery voltage is low.
058Z     The battery voltage is high.
066Z     In the ABS operation
067Z     In the ABS operation.
068Z     In the ABS operation.
069Z     In the ABS operation.
087Z     Fault with diagnosis output.
091Z     The warning lamp.
095Z     With the hydraulic connections.
096Z     The connections to the wheel speed sensors are transposed.
097Z     Is an external signal interference.
099Z     No fault is found.
PEUGEOT 306('97 sonrası ), 406(95-96), 605(96-97) Hata kodları
016Z     The BPP(Brake pedal position) switch.
018Z     Rotors of the wheel speed sensors.
042Z     The valves of the hydraulic modulator solenoid.
044Z     The valves of the hydraulic modulator solenoid.
051Z     The valves of the hydraulic modulator solenoid.
052Z     The valves of the hydraulic modulator solenoid.
053Z     The pump motor.
055Z     The ECU.
057Z     The battery voltage.
096Z     The connections of the wheel speed sensors are transposed.
Leon 1.6 DSG / 206 XT 1.4
