ZENON AND ABS PROBLEM
08.05.2020 20:09 # 1
HALIL.10
Hello, I just joined you, 2006 model 307 1.6 I'm a user of hdi, I am writing at this hour because my sleep has gone. Do not look at my fault. While the vehicle is running, the headlights and fog are close, especially the fog, the abs lamp and the stop lamp are on, these days are very frequent.
08.05.2020 20:09 # 2
ggitaristt
Welcome Wink
Every single thing in your car is connected to the brain. Everything in your car is electronically controlled. Even the bulbs. Ballasts of zenon lamps cause harmonics that affect the brain. I know friends who have been hurt by Zenon. So I did not dare and put it on ..
My personal advice would be to use a normal light bulb.
But do your research and you have been using it for years without problems.
ggitaristt 2017-01-28 06:50:01
08.05.2020 20:09 # 3
HALIL.10
the ones in the headlights do not burn, the interesting one Unhappy
08.05.2020 20:09 # 4
ggitaristt
I say, it does not affect it, how does it affect the electrician, is it poor quality, does not know how it affects the electricity of the vehicle ..
Then you took a look and started to work according to the head of the wipers ..
08.05.2020 20:09 # 5
Peugeot35
teacher, I use zenon, I had no problems, thank goodness saddle when your fog is burning, if the ABS light is on, STOP is flashing on the car, it is definite that there is a serious problem in the vehicle, STOP is flashing, the brain is detecting a problem.
Have you installed the original of the fog yourself? If it is not installed later, there is a wrong connection or improper installation, and the brain is not accepting this.
08.05.2020 20:09 # 6
Gokcesel
You have to wear xenon with Canbus so that my teacher does not light the fault. So it is not in the xenon fog with canbus in the headlights. I took it off because I said Smile First, put a halogen bulb in your fog, and if the fault lights go out, you will replace the xenos.
08.05.2020 20:09 # 7
HALIL.10
Just like I got zero zones in the headlights, the ones in the vicious fog are from the old zones, but we did something.
08.05.2020 20:09 # 8
HALIL.10
Meanwhile, the fog installation is original
08.05.2020 20:09 # 9
uguur
my brother when did you change the battery last time checked a battery and look at the amp
And if your car is in a good electrical system, check your installation. It may be short circuit due to xenon, but the example of making a battery is high xenon.
08.05.2020 20:09 # 10
Eakarsu
I think the battery is very low. In my car, the first time I started the car on the old battery, the airbag and stop were on for 10 seconds. The information I got from the service is also in the direction of the insufficiency of the battery. I would say that the electrician will measure the amperage and voltage given by the battery.
