Zavolli Help
08.05.2020 15:48 # 1
Bugra_Han
As of 3 days, I had a tube installed on my vehicle. Since the indicator showed red, after I traveled 83 km, I fullified again in terms of measurement.It took 30 pounds of gas. I am waiting for your help. Thank you.
08.05.2020 15:48 # 2
berk2309
I think it is better to use it in the cloth that burns a bit too much at the lpg. Replace your spark plugs with the lpg spark plug.
08.05.2020 15:48 # 3
cetin
What is the difference between LPG spark plug and normal spark plug? Question
08.05.2020 15:48 # 4
If you want a consultation with our cecoli friend, you can find the necessary answers.
respects
08.05.2020 15:48 # 5
orhanax
It seemed too much to me. How much was burning in gasoline? By the way, how many liters of LPG tank? Is it filled with 30 pounds? Wacko
08.05.2020 15:48 # 6
No measurement is made with the lpg tank because;
The lpg pump pressure of each station is different. Fulle fills 100 TL of the course. Fulle fills 90 TL of the course.
If the tube in your vehicle is a simit tube, no measurements are made because the tube indicators of the simit tube vehicles are visual. It does not tell the truth.
The most accurate way to find out how many cents your vehicle burns in the tube is to get some gas and reset the km as soon as you hear the warning signal is running out of the tube. if you suspect it is technically helpful ...
