z rot
08.05.2020 17:16 # 1
batuhan9292
When I went to my friend in the industry, I said that it came from the front, it was not continuous, sometimes he also pulled the car to the channel, shook it, said that the sound came from the z-rods. how much is the total cost
08.05.2020 17:16 # 2
hsnsnl
it is not a cost to be afraid of it, just change the rod rod
08.05.2020 17:16 # 3
batuhan9292
25 TL on the internet says z rotuna surprised the team is changing I guess I wanted to ask thanks
08.05.2020 17:16 # 4
hsnsnl
No yaw, you don't need to change the team. Whichever is bad, you just need to change it.
08.05.2020 17:16 # 5
ahmed206
There are lacquering sounds from the left front of my vehicle too, there is no quality master to know which part is broken here: S
08.05.2020 17:16 # 6
emre_akdag
z rot is changing only. You can control yourself with the lever. but the tool either & nbsp; you need to get it in the channel or lift it.
08.05.2020 17:16 # 7
[QUOTE = anonymous] There are lacquering sounds from the left front of my car too, there is no quality master to know which part is broken here: S [/ QUOTE]
I had the same problem. they changed from the right swing, it improved. The price is salty.
08.05.2020 17:16 # 8
[QUOTE] Even if you can go under it, you will understand that it is not a problem ... your problem is 90% of your arm. It costs like 30 TL .. [/ QUOTE]
I had the same problem, right swing + tie rod changed. I paid almost 200 lira including labor,
08.05.2020 17:16 # 9
Bugra
I have now changed z rods and rod heads. I did the maintenance of the filter while I was talking about my hand. I am somewhat original, no matter which vehicle I use, I do not wear sub-industry original peugeot rod heads, 50 tl. & nbsp; z rods are 50 TL each. 20 TL labor. I did not pay for the rod adjustment again. (because it is familiar) original oil, diesel, air, pollen filters: 90 tl catrol diesel 10/40 oil 65 tl workmanship30 tl
08.05.2020 17:16 # 10
ahmed206
There is no Peugeot master here, I will have to do this when I have to go to Fethiye. He also has no balance, I will go again and love somewhere else. & Nbsp;
08.05.2020 17:16 # 11
SDYMZ
I think it costs a lot if you replace it completely. rot balancers can find out where the sound is coming from
08.05.2020 17:16 # 12
ahmed206
They say there is a good service in Fethiye, special service. Let's take a salary, I guess I'll run there: D
I did not understand when I was on the lift, he said he was wearing the master lever and look at it.
