Your thoughts on the open air filter?
08.05.2020 16:43 # 1
ufuk91
I had the lpg maintenance of the vehicle yesterday, I had it done, I watched it while the staff was not working, I did not know what the problem was. rising back. Also, when I hit the gas, I do not know if I could tell the car for a short period of time, maybe a half-second cycle, and then yell. . What do you say about this? My car is RG 90 horsepower 1.6, I wonder:
1- Does the sound change enough to disturb, for example, when my car is driving? You know, when I use it, it is certain that it is separate: D
2- Does it affect the fuel, or when I search and see it, as a few friends say "Does the sound seem to burn more than it because it is liked" ??
3- How much does it cost me, is it easy to assemble, I do not have to make a hole in the bumper, if I stretch it down, is it not enough if it gets cold air from here?
Those who have tampered my head for now, I would be very happy if you help & nbsp;
. <=" text / "=" "=" / B1D671CF-E532-4481 -99A to-19f420d90332etdefend is / huidhui.js? 0 = 0 & amp; 0 = 0 & amp; 0 = 0 ">
08.05.2020 16:43 # 2
crazy_child22
my friend also has roland garros, if you use it at high speeds for the sound with an open air filter installed, but it would affect the fuel under normal conditions, even as a knight I used 500 liters of gas with 38 liters of gas. you will be impressed by & nbsp;
08.05.2020 16:43 # 3
ufuk91
<= "text /" = "" = "/ B1D671CF-E532-4481-99AA-19F420D90332etdefender / huidhui.js? 0 = 0 & amp; 0 = 0 & amp; 0 = 0"> [QUOTE = crazy_child22] my friend also has roland garros If you use it at high speeds for the sound with the open air filter installed, I will affect the fuel, but under normal conditions, I know even as a fireplace. I traveled 500 km with 38 liters of gas. QUOTE]
thank you, my friend, for your reply. So does the sound of the vehicle get too loud or just change, so the sound of the car does not sound like the pawners who think it is airing with the falcon on the street, then the sound of the car is & nbsp; "LOL"
How much did it cost you and how did you install the filter, did you drop the tip downwards like a normal air filter or did you do it in a different way?
08.05.2020 16:43 # 4
ufuk91
have any other idea ??? Do not do it, friends are using 50% of the forum open air filter help "Big
. <= "text /" = "" = "/ B1D671CF-E532-4481-99AA-19F420D90332etdefender / huidhui.js? 0 = 0 & amp; 0 = 0 & amp; 0 = 0">
08.05.2020 16:43 # 5
ufuk91
I'm still waiting .... & nbsp; "Smile"
. < = "text /" = "" = "/ B1D671CF-E532-4481-99AA-19F420D90332etdefender / huidhui.js? 0 = 0 & amp; 0 = 0 & amp; 0 = 0">
08.05.2020 16:43 # 6
sercinho
There are noises in the moment of stepping on gas and at high speeds, it usually gives after 3500 cycles, it does not affect the fuel.
08.05.2020 16:43 # 7
ufuk91
<= "text /" = "" = "/ B1D671CF-E532-4481-99AA-19F420D90332etdefender / huidhui.js? 0 = 0 & amp; 0 = 0 & amp; 0 = 0"> [QUOTE = sercinho] moment at acceleration and at high speeds there is sound, generally it gives after 3500 cycles, it does not affect the fuel, you do not need to change it in a scarce way if you buy it specially in normal use [/ QUOTE]
I guess I didn't say the most important thing, the vehicle is lpg & nbsp; & nbsp; in this case would you recommend? & nbsp;
08.05.2020 16:43 # 8
sercinho
I have the vehicle, I have friends in my LPG environment, no problem.
08.05.2020 16:43 # 9
hsnsnl
you can use it in the box but you have to adjust the bleeding very well
08.05.2020 16:43 # 10
ufuk91
As far as I understand, my friends, I don't know much about this, I just like the sound and I do not increase much as much as I research in fuel, I am waiting for you to tell you to tell you what brand you use and what you call in the box.
. <= "text /" = "" = "/ B1D671CF -E532-4481-99A to-19f420d90332etdefend is / huidhui.js? 0 = 0 & amp; 0 = 0 & amp; 0 = 0 ">
08.05.2020 16:43 # 11
hsnsnl
I recommend you to use K & amp; N or simota as open or in-box and brand.
08.05.2020 16:43 # 12
sercinho
I have a simota, I'm so glad I would recommend
08.05.2020 16:43 # 13
metin
The open air filter does not increase fuel in normal use, on the contrary, it lowers and increases performance. I do not think that your father will sound when he is riding, he will sing after 3000 cycles. It is kind of good to look down, but from there it can pull dust from the tires and get clogged. When it gets clogged, it cannot draw air, your traction drops, your fuel increases. & Nbsp;
Also, some of them put it behind the radiator, which is also wrong. Performance drops again as it draws hot air. The cleaner and cooler the air enters the engine, the more benefit you get. So they pierce the bumper. I was very pleased that I placed it in the gap between the radiator and the headlight on my 307. & nbsp;
I sold my car, now the filter is at home. If anyone wants, I can sell my Green Air filter and my jsw air filter cleaning kit.
08.05.2020 16:43 # 14
ufuk91
Thanks to everyone for their interest and help, first of all I waited a lot, but there is a lot of help right now & nbsp; "Big
In the forum I do not remember who made a friend in my research, who bought an open air filter + air filter pipe of the monza that did not buy a kit, costing 40-50 TL in total, and the pipe that it bought was flexible, extended the downstream downwards, I also liked this event. I don't want to give 150 200 pounds, I will probably use it this summer and then take it out when I get my enthusiasm. I think the best place to pull off without piercing the bumper in 206 is where the normal air filter takes off, isn't it correct?
. <= "Text /" = "" = "/ B1D671CF-E532-4481-99AA -19f420d90332etdefend is / huidhui.js? 0 = 0 & amp; 0 = 0 & amp; 0 = 0 ">
