Your System Recommendations
08.05.2020 17:07 # 1
electman
& Nbsp; & nbsp; & nbsp; & nbsp; Hello friends I have decided to have a small system on my 206+ vehicle. We are consulting the brands with my friend Alliance from the forum.
& nbsp; & nbsp; & nbsp; & nbsp; Okay Pioneer, sony, alpine, JVC, Clarion should be the reason for preference, but when I look at the features, it comes to the fore in a brand called Navitech. For example, if we compare "Navitech CDT-6950 BDT" with the known brands that have a bluetooth, TV or something blank.
& nbsp; There are some friends who use the forum, I believe that whatever navitechi impressions they share here will be beneficial for both me and other friends who are looking for tapes. Meanwhile Navitech CDT-6950 BDT subw. I am thinking of using with amphitheater and mid team
08.05.2020 17:07 # 2
Bugra
my friend my past experiences; the more features there is, the better is that. some companies collect these features in one product, but you cannot get full efficiency from any of them. Maybe it is different in the product you say, you need to investigate. Maybe all the functions he says are perfect. & nbsp;
08.05.2020 17:07 # 3
electman
The logic you say is not bad, but an old logic technology has developed. They do it now ... There is also a model of the same brand called DTV-7500. The features are; Motorized In-dash (inside) 7 '' touchscreen TFT LCD HD (800X480) high resolution DVD / VCD / CD / SD / USB / WMA / DivX Player High performance Internal TV receiver Handsfree Bluetooth Picture Settings: Brightness / Resolution / Color / Sharpness Screen Angle, Position Memory Repeat / Program / Random AM / FM Stereo Receiver RDS Radio Function Aux Input USB / SD Input 4X50W Mosfet audio output power Subwoofer Output Full Function Touch Screen Subwoofer Control Full Function Touch Screen Auto Memory and Search Reverse Camera Input 30 Channel Memory Additional Monitor Output 4 Channel RCA Output Card Type Full Function Remote.
08.05.2020 17:07 # 4
msk_sansal
hi i don't understand these things but i want something like that. Can I just do this without changing the orig tape, just changing my columns & amp; nbsp; amp? & nbsp; pop-stranger (I hate these types), while the hard pieces will be rock or foreign, again the hard foreign parts .. & nbsp; & nbsp;
as far as I follow here, comp .. there are separate groups & nbsp; which of them should I admit & nbsp;
(one member wrote coax behind them comp ..)
let's change this tape & nbsp; < span style = ": rgb251, 251, 253;"> DTV-7500 & nbsp; It looks like something very beautiful. but the questions are chasing each other, this time with your permission & nbsp; ..; & nbsp; & nbsp;
- will I have any problems with my on-board computer. ultimately on the menu vs orig tape. & nbsp; & nbsp;
you will ask for a budget now & nbsp; I can only allocate around 300 350 TL for columns. but I liked this tape too haa :)
Reviews
Reviews
08.05.2020 17:07 # 5
they said wrong, comp. Coaxial is mounted on the rear.
307 vehicles are 16 cm in front and rear are 13 cm in size. You should get coaxial.
If the front door does not break out, even if you replace it with coaxial, there will be no sound change. You should buy a tape with high output power for voice change.
08.05.2020 17:07 # 6
msk_sansal
Well, even if I do not change the tape, it would be time if I had a mid-way amp & nbsp; mu teacher. because in my car or in my normal life, org. I try not to compromise from everything. The simplicity of everything and the original is the best for me.
08.05.2020 17:07 # 7
Alicilik
[QUOTE = laedri] they said wrong, comp. Coaxial is mounted on the rear.
There is a monument 307. He was playing 16cm mid back and playing roaring.
Acoustic should be used the same everywhere. Coax heleki 13cm 16cm can not be supporter of midin
08.05.2020 17:07 # 8
of course, it must be a full set, coax la comp is not in the same lane. probably 16 cm to the rear has extended the slot in the inner floor. and if you get a 4-channel amp, the sound changes, of course. But the original tape's output power is not enough. Each speaker needs to go 50 watts to give the component the right.
08.05.2020 17:07 # 9
msk_sansal
just sprouted into my head :) & nbsp; road info on original tape. There are not so many options related to me .. it already interests me .. mode key tape or instant -total consumption & nbsp; feature is on the central screen .. we also set it from the button on the handle to delete it. & Nbsp; & nbsp; I think before replacing the tape, & nbsp; will be removed from the mode setting of the tape when the consumption menu is removed & nbsp; (we assumed new confirmation) .. & nbsp; What should I lie? I was upset when I was browsing a page or two .. & nbsp; & nbsp;
let's drop me a system now. & nbsp;
by taping 2din wrapped me a little bit navitech dx9800-9000 models & nbsp; (only medium-good I think)
front 2 comp rear 2 coax. (alpine cheap way or pioneer) woofer would definitely not want. & nbsp;
4 channels at one & nbsp; amp ........div>
did I set it up right now & nbsp;
08.05.2020 17:07 # 10
Alicilik
[QUOTE = msk_sansal] just hit my head :) & nbsp; road info on original tape. There are not so many options related to me .. it already interests me .. mode key tape or instant -total consumption & nbsp; feature is on the central screen .. we also set it from the button on the handle to delete it. & Nbsp; & nbsp; I think before replacing the tape, & nbsp; will be removed from the mode setting of the tape when the consumption menu is removed & nbsp; (we assumed new confirmation) .. & nbsp; What should I lie? I was upset when I was browsing a page or two .. & nbsp; & nbsp;
4 channels at one & nbsp; amp .... ....
Have I installed it right now & nbsp;
You should put a strong oval coax at the back. Otherwise, you will only get mid and treble sound. The interior of the vehicle will suffocate at high volume. Bass is a must for me. Reviews
08.05.2020 17:07 # 11
msk_sansal
Is not the oval coax you call the pandisot? & nbsp;
08.05.2020 17:07 # 12
Alicilik
[QUOTE = msk_sansal] Isn't it the pandizota that you call oval coax? & Nbsp; [/ QUOTE]
Yes teacher!
08.05.2020 17:07 # 13
electman
eee dtv-7500 what happened :) just looked at bimeks te 650 tl !!! gittigidiyorda 437,10TL is worth it. My head is completely confused there are so many options: S
08.05.2020 17:07 # 14
bass is a must, or mid-treble sound would be too much as your friend said ..
08.05.2020 17:07 # 15
msk_sansal
[QUOTE = Recipient] [QUOTE = msk_sansal] oval coax is not the sponge you call? & Nbsp; [/ QUOTE]
Yes, teacher
thank you my teacher you are right ... & nbsp;
4 speakers where we have come to where we came :)
08.05.2020 17:07 # 16
msk_sansal
[QUOTE = electman] eee dtv-7500 what happened :) just looked at bimeks te 650 tl !!! gittigidiyorda 437,10TL is worth it. My head was completely messed up. There are so many options: S [/ QUOTE]
look at me, let me get 4 speakers. through me. my day says dt-8600 or 8700 but i didn't know that & nbsp;
08.05.2020 17:07 # 17
Alicilik
The hawk we use is not born or 90 models. So you have to make the changes you will make to the system on it.
@ electman & nbsp; We are in touch with everything I explained to him. For me, it is a tape recorder. Because the amp and speaker will feed on it. He will forward to you that he has received from him. The first release should be of good quality, as it will come from it. (I'm not judging a brand here, I'm not saying this is good, this is bad.) The rest is all about your musical taste and economy.
I have a brother who uses a very friendly 206. We are together every day. jvc tape-boschmann amp (stereo) jameson amp (mono) - jbl 608c - pioneer 6994 and two different models pioneer 1000 bass (single box). When you open a bass song inside the vehicle, it has an air conditioning effect. But between 20 and 30 calm music, I can't get acoustic. It gives jbl mid front, ovals treble in the back, bass pattern is as if the head is tortured, chinese torture.
There is no clear sound and acoustics. I sound up to 30, 45-60 minutes on the road every day, believe me, the whole day is tired. After the helix insulated, the metal timbre of the vehicle was also cut off. I'm just listening to the sound coming out of the tape.
& nbsp;
08.05.2020 17:07 # 18
electman
We will try to isolate the set after the embellishment pattern ... In a vectra of my friend, the car's vibration sound was heard rather than the bass: S
08.05.2020 17:07 # 19
electman
I wish that if the dtv-7500 user came to put this endpoint on this tape, it could be bought or not
08.05.2020 17:07 # 20
msk_sansal
[QUOTE = electman] I wish the dtv-7500 user came to the end of this tape, so that it could be bought or not bought [/ QUOTE]
if someone else comes back & nbsp; trip computer etc is working or not working I got it)
Page : / 2
