Your simple sound system suggestions
08.05.2020 17:06 # 1
ataycan
Hello Friends,
I'm new to the forum. I would like to receive your knowledge on a few issues. I have 206 xline 1.4 automatic vehicle and I want to make a little sound installation. My budget is around 400 TL and it is limited. tape (around 180-250tl), 1 set mid to the front doors, or some coaxial speakers (80-150tl) according to your suggestions, just do my tape work without needing an amp? how is the cheapest jameson usa 434 1400watt I have mentioned the link below? By the way, I have the bass of the creative 6600 sound system at home, I don't know the 4ohm watts can I use it? I am waiting for your comments and suggestions. Thanks in advance.
& nbsp; kenwood any.
Reviews
Reviews
08.05.2020 17:06 # 2
Alicilik
Satisfaction and the kinds of music you listen to play a big role in the formation of the sound system. If you look at it in watts, you don't understand the difference between coax and mid. Do not look at the building as an electrician while entering the sound system business. There are many differences between infinity 120w and alpine 120w. Otherwise, if you listen to the man passing through the street, it is all the same. At this point, set your own points. Decide how you want tones. The main element of the audio system is the main unit. The material that ultimately forms the sound wave. You can use brands like pioneer-sony-jvc according to your budget. It was heard in brands such as Navitech-xetec-minton, but I did not listen, I will not be able to tell you about it. You will come to the crossroads after solving the main unit. After that, it depends a bit on the economy. using low current speakers that we call road coax. This is the least costly way. You can use two-way speakers of suitable sizes and vehicles of brands such as JBL-Pioneer-Sony-Kenwood. When you use them, there will be no amps and subsequent wiring, and the cost will be very low. If you say which model, which model, go, listen and get it. The ear is important. Otherwise, whatever you put on the door will sound absolutely. In my own car, there were ovals above the pioneer one-way and the two-way pendulum in the back. It was perfect at a medium volume, but it was disrupting towards the end, which was inevitable. 2. Using the more advanced mid-companent team with the help of the system amp and building a solid infrastructure budget event plays a big role in this section. Because an amp and component set that will satisfy your use cannot be less than 200-300. If you add this to the substructure, the assembly will not be removed. Isn't it possible to come out with a lower cost? But you will get as much efficiency as coax, you cannot go further. As I said, I don't know much about the sub that you use for SubWoofer. My friend has a double cabin bass pioneer two different series close to each other 1000w but they are very different tones bass. You can also provide the bass tone you want with quality ovals. The sound transmission of the vehicle is very important in this. While the e36 3.16i had the same music system as my 206+, we were getting every tone like crazy in BMW. But when the sound transmission of the pejo was not in and out, we could not get that efficiency. After all, the event is over for you. Here, friends will say that this brand is for sure, each of them has a valid reason, but you will listen to the music. Try to get it by listening as much as possible.
08.05.2020 17:06 # 3
Barut
I have the same problem as well, I am thinking of making a small installation of my vehicle 206 feline, but if we do not disassemble the original tape, would it be a problem? for
08.05.2020 17:06 # 4
Alicilik
[QUOTE = 206xs] I have the same problem as well, I am thinking of making a small installation of my vehicle 206 feline, but if we do not dismantle the original tape, would it be a problem? [/ QUOTE]
I don't understand why you obsess this screen in 206's. Whatever you do, you cannot transfer the necessary song information to the screen. So I don't know if it is necessary.
When you disassemble the 206s, the screen stays that way. Time and degree information always happens. Other than that, if the trip computer is on, you can see that information. If you had tape, besides this, when you turn on the tape, frequency information etc. will be released.
I almost regret that I gave 150tl to 3 lines. If the trip computer is a must, it's not super. Only yes there is a trip computer. What does it do? Instant fuel consumption fixture "LOL" The only feature of the 3-line display is the car scheme with the doors open, I was able to miss is something. Displaying the warning of the door that is open in the form of a diagram.
Do not worry about the screen.
08.05.2020 17:06 # 5
Barut
[QUOTE = Receiveness] [QUOTE = 206xs] I have the same problem, my vehicle is thinking to make 206 feline small installation, but if we do not dismantle the original tape, would it be a problem? [/ QUOTE]
I almost regret that I gave 150tl to 3 lines. If the trip computer is a must, it's not super. Only yes there is a trip computer. What does it do? Instant fuel consumption fixture "LOL" The only feature of the 3-line display is the car scheme with the doors open, I was able to miss is something. The door that is open shows the warning in the form of a diagram. The tape in my old car was not original, we had talked to you about the activation of the arm, but when the job was so hard, I couldn't do it, I had a set in my old car.
08.05.2020 17:06 # 6
Alicilik
[QUOTE = 206xs]
& nbsp; there is that problem in me, I want to keep the doors open, be warned, and I want to have the steering control active most of the time, the tape in my old vehicle was not original. I had a set in my car, now I want to do something in the car I bought, I want to do something small, but if the tape remains original, does it matter in terms of sound? 3 lines or one line?
Display joystick independent events. you will take the tape and put it on, then you will either have the commander in Izmir or bring a piece from abroad.
The sound system has no input or output like a disease. Satisfaction is very important in the ear. I am using the original GT5-12 of JBL. I tried the Pioneer 4-5 series power bass alpine, I couldn't find the exact tone I wanted. Nowadays, my situation is not tight or I have a vibe, I will try it, or jbl has a top series and I can switch to it. & Nbsp; Reviews
08.05.2020 17:06 # 7
Alicilik
By the way, my suggestion about original tape-oem tape is always oem tape. You cannot drive the outputs of the original tape directly to the amplifier. You will need to use a dialer. In this way, the yield you will get will necessarily decrease. As I mentioned in @ 2, the main unit will give the most important sound. & Nbsp;
08.05.2020 17:06 # 8
hsnsnl
@alcılık friends explained everything ..
& nbsp;
If you are going to make a low cost beet, I think you do not get the piece ... put it on the edge, then install it to your car .. the money that comes with it will come to you. I made it like I said, but I couldn't stand it and got what I got: my friend make it full and always look at using the same brand ..
08.05.2020 17:06 # 9
DS002
I have installed 2400 watts edison amplifier, 500 watt ponyone bass 4 sound column, bidet treble set 10 sound, I think it is ideal :)
08.05.2020 17:06 # 10
Buy one 4 * 50 cd plaer,
Coaxial to the back door may not be necessary, but the backs are very bad in the original.
150 cd player + 80 coaxial 220
If you change the front, 300 TL in total ..
