Your Opinions About FK 3,5 cm Sports Bow
08.05.2020 16:03 # 1
I have 16 Peugeot Wheel in my friends car. I want to attach a 3.5 cm Fk brand sports bow to my vehicle and I want to act by taking ideas from friends who know the pros and cons. Thank you very much for your information. Respects...
08.05.2020 16:03 # 2
father, 3.5 cm bow does not think 307, I know there have been many attempts. If you say at least 5 cm or flattened vehicle I want, you will get 6 cm spring.
your comfort becomes 0 when you wear the spring
08.05.2020 16:03 # 3
Should a damper change be required in 5 cm?
08.05.2020 16:03 # 4
some say it is different but i haven't seen much of it
08.05.2020 16:03 # 5
I saw expressions such as how much the car will be lowered in 5 cm.
08.05.2020 16:03 # 6
yes there are articles on it but i can't leave much need to change the same car has a friend of mine had a 45mm spring it was sufficiently low on the vehicle
08.05.2020 16:03 # 7
I am a family of 5, 3 of them children. If it is too low, there will be a problem for me, but I am surprised at what I will do if I feel pissed. Confused
08.05.2020 16:03 # 8
34sea45
3,5 is an ideal spring, if it is used with the family, you can attach the vehicle at 5 cm. 3.5 is always better if used family car with turkey conditions
08.05.2020 16:03 # 9
[QUOTE = 34sea45] 3,5 is an ideal spring, if it is used with the family, you can attach the vehicle at 5 cm. If your shock absorbers do not recover, you can change or shave your existing shock absorbers. If the vehicle used in the turkey family conditions are always better than 3.5 [/ QUOTE]
dude 3.5 ideal yes 106 for blah but does not fall 307 very high dishonest Sırıtma
08.05.2020 16:03 # 10
Does the vehicle stand flat with 3.5 cm?
08.05.2020 16:03 # 11
My friend, I do not recommend FK brand, the choice is Eibach.
08.05.2020 16:03 # 12
34sea45
[QUOTE = EmRaH] [QUOTE = 34sea45] 3,5 is an ideal spring, if it is used with the family, you can attach the vehicle at 5 cm. If the vehicle used in the turkey family conditions are always better than 3.5 [/ QUOTE]
knka düşürmüyyo you diyiyo + 5-person family, but I think the ideal ways of turkey
but in general it is up to the person to enjoy
If it is up to me, I will print it until the car kisses the ground.
08.05.2020 16:03 # 13
Emre Ekrem
The fk never drops as much as it says on it, I recommend you to measure a vehicle fitted with fk, if you are going to see the eibach or the cone, if you say no fk, you should buy a sports spring because the 3.5s drop down by about 5mm and the original shock absorbers may not be able to withstand it.
08.05.2020 16:03 # 14
[QUOTE = HeRo1727] My friend I do not recommend the FK brand, the choice is Eibach. [/ QUOTE]
Alkış
Alkış
Alkış
08.05.2020 16:03 # 15
okan4037
[QUOTE = undertaker] fk never drops as much as it says on it. [/ QUOTE]
First of all, I disagree with any of your comments ...
1- Read the comments of friends who use FK After H&R, FK is the most lowering bow ... decreasing the value it says exactly ...
2- No 3.5-inch spring will drop 5.
As for the subject; I do not recommend Fk, although it is cheaper in the market, I recommend you to buy Eibach 50 mm, so sportline model ... you will be softer and you can even hit x6 selector in the bend :)
Even turkey 1 307 people took 3.5 cm s, I'm glad he does not heralde must be 5 cm for nothing when you said would be a waste of cash at least spring sports! It is not rubbing anyway with 17`50`205.
The shock absorber is based on 5 cm ee so it would be better if it changes, but it is not necessary.
08.05.2020 16:03 # 16
[QUOTE = okan4037] [QUOTE = undertaker] fk never drops as much as it says on it, I recommend you to measure a vehicle fitted with fk, if you are going to see an eibach or cone, if you say no fk, you need to buy a sports spring because it drops 3.5 mm up and down 5mm. original shock absorbers may not be able to handle it. [/ QUOTE]
Thank you very much for your information. Respects....
08.05.2020 16:03 # 17
Emre Ekrem
These things are completely fixed with experience, I am sure that you are, join or disagree, I told you according to what I have experienced and what I see, I have eibach prokit in my car now 3mm plus 4ad cone for support yellow and powerflex chock made for high performance and my car does not play from the bend. Unfortunately, companies such as FK, H&R do their lowering kits according to the whole group of a model, for example, 307 hdi and 307 1.6 gasoline are not the same, but the spring is the same, 3.5 says but 4 or 5 drops from the weight, or 6. no bow for 3o6, what do we do and we get 2o6 or 1o6 3.5s 6 falls. Whatever is suitable for your budget, you can see what you measure, you will see the meter, I just say that the result is 3 frustrations, not to be disappointed. undertaker 2011-08-26 10:50:43
08.05.2020 16:03 # 18
[QUOTE = undertaker] These things are completely fixed with experience, I'm sure you are, join or disagree, I told you what I have experienced and what I see, now my car has eibach prokit 3mm plus 4 cone for support yellow and powerflex chock made for high performance and my car will not play miles the bend. Unfortunately, companies such as FK, H&R do their lowering kits according to the whole group of a model, for example, 307 hdi and 307 1.6 gasoline are not the same, but the spring is the same, 3.5 says but 4 or 5 drops from the weight, or 6. no bow for 3o6, what do we do and we get 2o6 or 3o6 3.5s 6 falls. Whatever is suitable for your budget, you can see what you measure, you will see the meter, I just say 3 cents more, not to be disappointed. [/ QUOTE]
I understand, thank you very much for your interest. Respects...
08.05.2020 16:03 # 19
ozdemirosman
How about the sport springs, friends, so there is a coil spring in the front, they can attach it instead, but there is no such spring in the rear shock absorber in the 106s? where do they install it? there is a shock absorber like a thin air pump .....
08.05.2020 16:03 # 20
ozdemirosman
It is güüncel.
Page : / 3
