Your antifreeze suggestions ..
08.05.2020 20:32 # 1
Brcbyrktr
Hi friends. 2003 206 1.4 hdi (220.000 km.) What are your antifreeze suggestions for use in my vehicle? I had an antifreeze on orange (I think I had read this organic barrier) before, and now there is only water as a result of some troubles.
08.05.2020 20:32 # 2
Hodja, first, take pure water and put some water and then it drains. Castrol has a blue antifreeze from it, then take a 3 liter canister.
08.05.2020 20:32 # 3
Brcbyrktr
You son. Is this blue better than you say to my whistle?
08.05.2020 20:32 # 4
Well, brother, first of all, I put red on you. We have spent a lot of money then I always used blue, no problem.
08.05.2020 20:32 # 5
samet206
I recommend blue antifreeze, I used it myself, I had no problems with blue. But when I put it purely, the repairman once put it, I did not know when I was putting it, then I had some problems.
08.05.2020 20:32 # 6
yigit_dark
I am always afraid to put antifreeze on the vehicle. The masters act according to their heads. The car empties 3 liters while running. It doesn't put any water on it, etc. I knew red well. 500 km of oil left for my vehicle. It is close to winter. Antirifiz, I put it in me. We will be informed if you write what happened to your vehicle while you are making a change.
08.05.2020 20:32 # 7
Orcun.Dmr
I have never filled antifreeze, I have only been using it with water for 7 years, I changed its water recently, nothing like rust or mold appeared in the water. If I drain the water again and fill the antifreeze, would it cause a problem?
08.05.2020 20:32 # 8
samet206
Since the vehicle has been used with water for such a long time, it is very likely to leak from places as soon as antifreeze is added.
samet206 2017-08-28 00:52:31
08.05.2020 20:32 # 9
Orcun.Dmr
[QUOTE = samet206] Since the vehicle has been used with water for a long time, it is very likely to leak from places as soon as antifreeze is added.
I used it with water for a long time, but I made the water change constantly, the water did not stop much in the engine. I absolutely trust my vehicle, but as you said, I am uneasy if I do not fill it because it is risky.
