Your 407 indicator lights are blinking,
08.05.2020 19:42 # 1
EmreGun
Hello friends, I joined 407 last week. My vehicle is 2005 model 2000 engine automatic LPG 175000 KM, I am happy with the use of my vehicle, but I have a problem say, I would be glad if you help.
While on the move, the tape instrument panel suddenly starts to blink, ABS and air bag fails, the hands reset to the left, then the engine turns on the malfunction lamp, and this cycle repeats continuously, but there is no problem with the car going.
What is the cause of this malfunction?
Thank you in advance for your help.
08.05.2020 19:42 # 2
xmen
Hodja, good luck, you will use your vehicle on good days. Let's measure your battery values. Let's see if there is a problem ...
08.05.2020 19:42 # 3
EmreGun
Thank you, they said I had the battery values measured in a special service, they said normal, they connected the vehicle on the computer, but there was no malfunction code.
08.05.2020 19:42 # 4
talip206
If the problem is not the battery, if we go from simple to difficult; Have the charger rated. But have it measured in motion, not while standing. a job that requires some patience and attention. Because sometimes it may not stop or always do. There may be over or under charging. The second possibility may be a problem in the brain.
08.05.2020 19:42 # 5
fætih
test the charger for a long time. 90% of your problem is caused by this
08.05.2020 19:42 # 6
EmreGun
Thank you for your attention, friends, I took the car to the service today, the master is very good, found the fault immediately, the parking sensor in the trunk is making a short circuit with the brain wet, stuck, no problem for now
