You have a Peugeot, you have a problem !!
08.05.2020 18:40 # 1
E.B
I know that now everyone will be making me a site because I have a title, but it is not as much as I do with peugeot 2003 model 307 xsi I have it for 1 year
I have always wanted to use the original and the best quality since I bought it. I am a university student.
the rod rods have changed, the pressure is the lining, the engine oil, the full maintenance of the oil, the bill is on me, and there is so much I forgot
Anyway why do I rebel? I just got out for an important job, I stopped in one of the cafe, I was in Cyprus to make a photocopy, I took a photocopy, 40 degree hot, I took a copy, I got into the car, cit cit, I looked at the battery, finished, I said 2 nerves or something went up, I called ustami, brought a battery, then checked the guy, he said that the radiator was broken. And here it shows where the antifreeze flows, and now I have no excuse to buy a radiator when I have consumed zero.
08.05.2020 18:40 # 2
E.B
how long do these radiator blocking agents handle me? I need something that will take me 1 week 10 days: S then I will buy a zero radiator
08.05.2020 18:40 # 3
kAramsAR
My friend, first of all, about 6 years ago, we burned the gasket due to the leakage of my radio and it cost me around 1200, it was not even possible for me to call and see the attractive money. You have survived very cheap. But there are some vehicles that can not solve the turbo supply, there are some that do not go over 130 km, my oil burning does not shift from the engine, I do not say that it does not work in the morning, what more of these things are, there are so many people who cannot find a solution to them, sweet faults I think you should be thankful for this :) Remember, peugeot candır rest is excited :)
08.05.2020 18:40 # 4
Barut
I think the phantom vehicle is ultimately the servant structure, what I saw costs I paid 5 thousand to my old vehicle, even while selling 2 thousand expenses, yours simple problems are solved.
08.05.2020 18:40 # 5
kAramsAR
These are the radiator plugs that the masters take into the first hand when there is a problem in your vehicle's radiator, or rather, in case of a radiator incontinence . Small capsule in powder form that looks like sawdust in it. If your car is leaking water and you think that this escaping water is caused by the radiator; I recommend you to use it first. One-on-one for the small holes in your radiator. The radiator varies depending on the vehicle, but it is an expensive auto spare part. For this reason, I recommend you to try this 5 pound radiator plugs first. These are also American brands, the Gunk brand. He is better quality, and a little bigger. I think it is around 8 lira. When you throw this into the radiator, it closes the small holes and you get a very effective method knowledge.
http://i.hizliresim.com/aq4XoB.jpg for your information, I opened the die :)
08.05.2020 18:40 # 6
E.B
All you said was right on the zewklee that I was getting into my car but when I had no money, it would be a very difficult problem.
08.05.2020 18:40 # 7
E.B
My first job will be to look at it tomorrow, so how do I add it, I will pour it out of the radiator water? so inside the white warehouse?
08.05.2020 18:40 # 8
kAramsAR
If you do not have a situation like repair, my opinion is harmful, but if you say I will change it soon, I think it will be useful die Thumbs Up
08.05.2020 18:40 # 9
E.B
Manage it for 15 days is enough :)
08.05.2020 18:40 # 10
Serkan
I think you have a problem with your car, you can have all sorts of problems in every brand, and it can be users that every brand disgrades when satisfied.
08.05.2020 18:40 # 11
Alicilik
:) If you want to have a car without problems, you will get a 5-year warranty with zero warranty. Subsequent malfunctions and problems then change chronically and climatically depending on the priority user. Do you ever look left and right before the car gets on? Radiator water is antifreeze and is evident where it drips.
The weather was very hot, I used to take a taxi until the car was repaired
08.05.2020 18:40 # 12
E.B
No, I am not saying that there will be no problem with the vehicle, only when it is overlaid and resetting the money in the pocket, the human is getting angry now I got on the h.I went to the field.
08.05.2020 18:40 # 13
E.B
Meanwhile, I bought a stop leake, the oil for the radiator came out. How do I use anybody using it? The man will pour it into the radiator for 10 minutes and said the car, but as far as I remember, does our peugeot 307 have a radiator cap?
08.05.2020 18:40 # 14
ahmed206
It does not have a radiator cap but it can be poured from the pipes.
Brother, if these are your troubles, these are things that can happen in all cars of that age. Even if Mercedes, the lining battery can run out and its radiator can also be pierced.
08.05.2020 18:40 # 15
E.B
I didn't know exactly how I could pour, do you know exactly how to stop leake in?
08.05.2020 18:40 # 16
ahmed206
I have never used it, I think if you can stay without a car, do not enter it until you change the radiator bro. Maybe it will cause other troubles, but it will make more effort then I say.
08.05.2020 18:40 # 17
samet206
I think it is the situation that causes you to rebel, but it is not unfortunate that all the vehicles are 3 years old. The pluggers work, but for a while you throw the drug, you sell the drug, you sweat behind it.
08.05.2020 18:40 # 18
_ali_
There are also products blocking the outside. I adhered the solar energy pipe and it does not even drip outside. Also, if the vehicle is older than 5-6 years, I think such problems are normal.
I agree with a friend on the subject, the underclothes of the pugs wear out very quickly and miss the setting, because our country does not have designs that are suitable for the road situation.
08.05.2020 18:40 # 19
peugeot murat
If you have trouble, you have a problem with everyone, but never mind, there is worse.
08.05.2020 18:40 # 20
E.B
What if I had my sunroof on my image, I wouldn't have enjoyed it 4 months ago, I poured the money of the world 4 years ago. Now you use it, you burn it, I appreciate it, you will give it to me.
Page : / 2
