yet another problem
Homepage » PEUGEOT MODIFIED PLATFORM » How To
08.05.2020 17:23 # 1
gngburak
Greetings
my car 206
When I go with my
car, there are some sounds like a back creak. I sprayed the spray & nbsp; nafile
exhaust is not sounding there
where might it come from ...
08.05.2020 17:23 # 2
taylan2
I have the same problem, I think they come from the back tailgate, they click it
08.05.2020 17:23 # 3
mistik
when you open the rear trunk, there are two rubber rubbits next to each other. When you close the trunk, you should be on top of the colony so that they do not move from the colony.
08.05.2020 17:23 # 4
fxmen
put the rear trunk ac pantizod there, there is a pin that moves in the bag of the trunk, that sound comes from there, I found it crazy, but if you change it very hard to find the solution, I did so, I did not hear the sound of wearing it on the head, I did it, I did so, until I found the problem of the problem
08.05.2020 17:23 # 5
206hdisw
most likely it was from the rear torsion bushing it had been in me like nerve boxer like the door creak, it disappeared when you changed the torsion bushes
08.05.2020 17:23 # 6
fTh206
Those voices were coming from 5 doors in 206, I couldn't find a solution, I tried 3 years & nbsp;
08.05.2020 17:23 # 7
gngburak
[QUOTE = mystic] When I open the rear trunk, there are two rubber rubbits on the inside of the interior. When you close the trunk, you can get over the colony. comes from the side. it becomes more obvious from the outside gngburak 2013-02-28 08:08:47
08.05.2020 17:23 # 8
gngburak
[QUOTE = 206hdisw] is probably coming from the back torsion bush it had been in my mind as the nerve boxer was lost when I changed the torsion bushings.
08.05.2020 17:23 # 9
gngburak
[QUOTE] "Smile"
[/ QUOTE] was coming from there too I took care of it
but this sound comes from outside while it is outside it becomes very obvious
08.05.2020 17:23 # 10
arachnid
a sound like the sound coming from old springy sofas. it could be torsion if it comes from the rear wheels when it shakes the car from the back. 400-500 TL
08.05.2020 17:23 # 11
gngburak
[QUOTE = arachnid] A sound like the sound from old springy sofas. it could be torsion if it comes from the rear wheels when it shakes the car from the back. 400-500 TL
[/ QUOTE] exactly, but I'm tired of having these torsion balls
