Yellowing of the signals
Homepage » PEUGEOT MODIFIED PLATFORM » How To
08.05.2020 20:11 # 1
Ugurcan57
Hello
I am thinking of making an American parking module tuned to my 406 vehicle, but the signals are not even related to very pale and yellowish orange. How can I solve this? I am waiting for your answers
08.05.2020 20:11 # 2
ggitaristt
Orange foil?
08.05.2020 20:11 # 3
Ugurcan57
I came to my mind, I do not like that chip, do not have any other cares?
08.05.2020 20:11 # 4
Gokcesel
Osram diadem becomes the solution point.
08.05.2020 20:11 # 5
ggitaristt
[QUOTE = Gokceel] Osram diadem becomes the solution point. [/ QUOTE]
Do not get damaged when the bulb is constantly lit? American park says ..
08.05.2020 20:11 # 6
Gokcesel
[QUOTE = ggitaristt] [QUOTE = Gokceel] Osram becomes the diadem solution point. [/ QUOTE]
I have not seen the damaged yet Smile Although he sees the most change is made that he will not see in a short time. The bulb I have bought is 10 liras and its color tone and illumination are beautiful. The problem of the friend is already a light bulb Tongue
08.05.2020 20:11 # 7
Ugurcan57
I did not know the osram diadems, but as a result of my research, it will be noticeable that there is only one thing that comes to my mind. Does these lamps fit the signals of 406?
08.05.2020 20:11 # 8
Gokcesel
[QUOTE = Ugurcan57] I did not know the osram diadems, but as a result of my research, it will be noticeable that there is only one thing in my mind. Does these lamps fit the signals of 406 [/ QUOTE]
Here you can learn the bulb types by choosing your vehicle model. 99% BAU15S socket bulb Smile
08.05.2020 20:11 # 9
kskl
Slmlar 2001 406 sv 280 thousand km I do not want to buy today but I do not have any information about the vehicle.
08.05.2020 20:11 # 10
[QUOTE = kskl] Slmlar 2001 406 sv 280 thousand km I do not want to buy today, but I do not have any information about the vehicle.
First of all, welcome to us. The normal km obsession according to km age is only available in our country, 406 comfort and width does not upset you. take good care of the engine is probably lpg l. Ask them when the last heavy maintenance was done and have them checked. Have engine antifreeze in the vehicle or if you put it, you will have a lot of trouble when you put the engine compression test. refer to engine oil leak etc. Do you use the vehicle for 5-10 minutes, go through the bumps, there is no different sound, grip, traction, brake tremors. Have a good control of the chassis and poles due to its age.
