Yellow fault lamp
08.05.2020 17:53 # 1
Caner mihci
1.4 hdi 2004 model 307 they have to do with heating.
08.05.2020 17:53 # 2
reality59
If the vehicle is LPG, it is not an important mistake (LPG gives a mistake because it breaks the system, it gives an error because it reads the different fuel from the sensors.);
In addition, the reasons;
1.Dirty fuel
2.The catalyst is clogged or malfunctioning
3.The lamp sensor in the exhaust system is measuring incorrectly.
You can look at the exact name of the "Antipollution Fault" error in this booklet .
If you search, there is information about the subject under the forum.
reality59 2013-08-20 23:39:30
08.05.2020 17:53 # 3
yenice
This light comes on when the ignition is switched on for the first time, but I remember it goes out
08.05.2020 17:53 # 4
reality59
needs to go out after starting the vehicle
08.05.2020 17:53 # 5
Caner mihci
Since the vehicle did not go out after the diesel vehicle started, I had to open a topic. Thanks for your interest.
08.05.2020 17:53 # 6
halilefe
My brother had the same problem as well. It might have been due to anything related to fuel. For example, the problem in me was that the yellow lamp was on beside the engine malfunction lamp. it is something simple you too.
08.05.2020 17:53 # 7
samet206
The most guaranteed link to the computer is to find the error code and see what happens.
08.05.2020 17:53 # 8
mami202
exhaust emission problem warning light as indicated by friends, there is a problem related to catalyst or exhaust, hopefully not expensive if catalytic converter is problematic
