Yelling after 110 km
08.05.2020 20:49 # 1
307XS307
Hello friends. vehicle 2004 model 307 xs 1.6 automatic lpgli. While the car is driving at a speed of 90 km, it is quiet normal, but when it comes to 110, it starts to scream excessively, and you almost think it will not exceed 110 but of course I went up to 180 even if it was forced or late. Of course, you can guess the sound of the car that shouts at 110 while driving at 180. what is the reason of this ?
NOTE: I had 99 models of 1.4 lpg polo 140, even when pressing, it was going like silent oil. Although this pejo is 1.6, it starts screaming at 110 km. what is the reason and solution for this
08.05.2020 20:49 # 2
KILIC
You know, 4 forward gear teachers. may be because of him yelling.
08.05.2020 20:49 # 3
307XS307
So this is normal, hodja?
08.05.2020 20:49 # 4
serdarr4
The vehicle's shouting at low speeds indicates that the need for pressure pads is approaching. The easiest way to understand is to pull your hand firmly (tear off the rope) then try to lift the car and see if it will drag the back. If he shouts a lot and does not get up, the pressure may be lining. The first thing that comes to mind.
08.05.2020 20:49 # 5
307XS307
My teacher says that the pressure will not start in automatic transmission vehicles.
08.05.2020 20:49 # 6
ggitaristt
Even sibling manual cars make 90 at most 100 at 3000 rpm. Normally, at 110, I think it is normal for a 4-speed car to shout.
08.05.2020 20:49 # 7
talip206
[QUOTE = 307XS307] my teacher says the pressure will not start the pad in automatic transmission vehicles [/ QUOTE]
Yes, yours is automatic, printing will not start the pad. Interestingly, he screams in me 110 too, but after he passes 110, he screams less
In normal conditions, when going with 110, it should be around 3000 cycles. It shows you how many cycles.
08.05.2020 20:49 # 8
boruc
[QUOTE = talip206] [QUOTE = 307XS307] my teacher says there is no pressure pad in automatic gear vehicles [/ QUOTE]
In normal conditions, when going with 110, it should be around 3000 cycles. It shows you how many cycles. [/ QUOTE]
It feels just like you said to me. I hear 110 more sounds as if I think the sound gets thinner when the cycle goes up.
206 1.6 110 hp
