yardımmm
08.05.2020 21:28 # 1
Hoholis
Good luck to everyone. I have a peugeot 307 vehicle, when the diesel tank is less than half a tank, I put an injector cleaner on the tank, I used the car for a little bit, but the car started to work like a tractor. Now my question is that there is no sound when the vehicle is idle at the moment, but when the gas is pressed or when the vehicle is walking, it makes a click or decrease in parallel with the gas. One master looked at the vehicle, the engine wrapped around the bed, said, do not move the vehicle, said a master, the injector said, I was surprised. I did not understand what was the fault light on the car or the problem is not gone. I would be glad if you could help. Events such as late work and white smoke started now. Hoholis 2020-02-23 23:32:28
08.05.2020 21:28 # 2
FatihBall
Check the diesel filter Is the edges of the injectors of the vehicle wet?
08.05.2020 21:28 # 3
If you do not use products such as cleansers for a long time or after using high quality fuel, you may encounter such problems. the reason is deposits in the fuel system etc. diesel filter and injectors may be empty. the estimated cost will be between 150 tl and 1500 tl. replace your car's fuel filter first. then injector values etc. Turn heads.
