Yardim Lazim Acil ARAC 3000 cycle does not pass
08.05.2020 21:06 # 1
ffeetthhiiyyeellii
ARAC 206 xs 90L high operation, 2-3 thousand cycles, stop, delay, etc., let the problem start, and when it is connected to the veteran, gasoline seconds too high when it is connected to the computer, they said, potentiometer malfunction.
the ffeetthhiiyyeelli 2018-12-26 23:47:37
08.05.2020 21:06 # 2
First of all, welcome to us. Even though the replaced parts give fault codes, sometimes there may be events such as oxidation in cables - sockets. First of all, use your vehicle in gasoline and have to have some gas pump pressure and engine ecu sockets checked by fuse boxes.
08.05.2020 21:06 # 3
ffeetthhiiyyeellii
I checked all of them, I found the crank sensor from someone, I installed it, I did not fix the plugs. CryCryCry youtubeyede I'll throw pejo more if I get on ....... if they can go to the veteran tomorrow, they can tear it up.
08.05.2020 21:06 # 4
unfortunately it's hard to find a peugeot master. First of all you have to solve the problem in gas, bro.
Although 1-petrol pump pressure is working normally, a situation encountered in many vehicles with LPG is not enough cooling when the gas is available when the quarter tank is constantly taken. As a result, since the vehicle does not have enough gasoline to press the gas, the vehicle does not eat gas, etc. is causing. only the pump is sold. The price would be around 100 TL. no need to replace the float completely. I also recommend you to measure the voltage coming to the pump. It may be necessary to change the relay of the gasoline.
Clean the 2-map sensor and throttle well.
3-exnon-sound system etc. to your vehicle afterwards. Done access. cancel them and turn them into original.
4-end engine may be welded in ecu sunda and dismantled and circuit control should be done.
08.05.2020 21:06 # 5
KvncKR
map sensor lpg fuel hoses I have experienced the same problem in time at 106 xs lpg fuel hoses are filled with mud. The map sensor does not read the ideal values. This has nothing to do with the ECU setting. I recommend that you do not ride with gasoline under the quarter tank.
