Yag Client
08.05.2020 16:25 # 1
vapio
Good evening;
I noticed that oil was pouring on the floor on my 206 vehicle in the morning. If I used the vehicle in this way, it would be distressing for me to check the oil from the oil cube. I haven't seen you burned any more.
08.05.2020 16:25 # 2
yavuz25
Oil work is very important.If you have to use it, you should check the oil level on the dipstick before you go.
08.05.2020 16:25 # 3
sahin-peugeot
I don't think that the leakage of oil will be from the oil sender, they may have left it loose, but he misses it like that, if it is a problem, changing it can change it in two minutes, no matter how intense it is.
08.05.2020 16:25 # 4
djchaos
[QUOTE = sahin-peugeot]
I don't think the leakage of oil will be from the oil sender, they may have left it loose, but it will miss it, if it is the problem, it can change it in two minutes, no matter how intense it is. / QUOTE]
+ 10 & nbsp; "Thumbs
08.05.2020 16:25 # 5
toprak
If your sender is broken, on the trip computer & nbsp; insufficient & nbsp; Shouldn't you get a warning like oil pressure? Turkish insufficient oil pressure. In fact, your oil pressure is good, but due to malfunction, the error will return.
08.05.2020 16:25 # 6
vapio
I would appreciate it very much for your information. I went back early this morning and looked at the oil again, and the oil flowed again.
I think I am from the filter, I show the filter to the master, say sweating. br>
" border = "">
08.05.2020 16:25 # 7
06OzGuR06
Sweating? Brother is officially kidnapping & nbsp; oringi change its gasket, master. I see such sweating for the first time. br> 06ÖZGüR06 2011-12-04 18:57:59
08.05.2020 16:25 # 8
toprak
Wait a minute. What the oil is doing under the start of the exhaust. : Did you move the S vehicle?
