XENON ISSUE :(
08.05.2020 15:11 # 1
masumserseri
mrb friends
Today, I installed xenon kit on my vehicle. :D
But whatever I did, the left eye xenon is not flashing. I take the right to the right. No problem. It is burning right. The balance is the same. I changed the balance, I changed the bulb.
08.05.2020 15:11 # 2
It was as if something like that had been mentioned in the night, but I may be wrong. They solved the problem by taking the negative directly from the battery, not from the aquarium, but I cannot fully remember that it was such a problem. Maybe that's the problem?
08.05.2020 15:11 # 3
oguzhan29
yes they got the fault problem, you can find it from the forum by doing some research or show it to the electrician
08.05.2020 15:11 # 4
masumserseri
Which sleeper has in mind.
08.05.2020 15:11 # 5
- Try to get the cable from the ground around the headlight directly from the ground. not from the battery or socket ...
08.05.2020 15:11 # 6
masumserseri
I can't handle it :(
08.05.2020 15:11 # 7
then you will have it. :))))
08.05.2020 15:11 # 8
masumserseri
Whenever there is an opportunity, I came to Aksaray to get xeno, I got out early or I would get rid of you the masumserser 2011-03-25 21:15:22
08.05.2020 15:11 # 9
metin
The headlights are lenses, I hope you do not have a halogen headlight xenon if you get the best quality, you won't be able to see it, it will be a pity in front of you.
08.05.2020 15:11 # 10
Didn't you look for the light?
08.05.2020 15:11 # 11
masumserseri
msg box is full, be your news: DD
08.05.2020 15:11 # 12
masumserseri
headlights fabrication.no need to find a solution.I need to find a solution.If I do not find a solution, the electrician leads the way: D
08.05.2020 15:11 # 13
EmRe26
There are little holes in the headlights if you try them? with a small bolt nut?
08.05.2020 15:11 # 14
masumserseri
I can't handle these cable jobs.
08.05.2020 15:11 # 15
It looks like your tool hasn't changed :)))))))
for your homeland you will gladly go to the electrician :))))
08.05.2020 15:11 # 16
masumserseri
When I say the key to my hand, I am also aga babies: D. I do not understand the electric heat. The only problem is that.
08.05.2020 15:11 # 17
ooooo if you know that much heat, you can fasten a minus cable to the chassis. Sırıtma
08.05.2020 15:11 # 18
masumserseri
There are two ends in the socket that comes to the back of the light bulb, the bases are heat pressed.
08.05.2020 15:11 # 19
Then you will get your brother to the master for 2 minutes and you will learn the heat ...
08.05.2020 15:11 # 20
masumserseri
Yes, it seems I will get it at the first opportunity.
Page : / 2
