Xenon Ideas and Help
08.05.2020 15:23 # 1
tigerland
Hello friends,
the day before, the right xenon 6000K bulb cut off I ordered from Hepsiburada.com, so that there are 2 color differences, 8000K coming to me is burning blue, but blue is very beautiful .. now the fog is white headlights are burning blue. But when I turn on the fog, sometimes I open it, usually closed fog.
Do you think I should send the amps back and make 6000K and fog lights the same color or do I use them without changing these incoming bulbs? Should I use fog white headlight blue in this way?
Can you help me as an idea? On the other hand, send back with 6000K team get spoiled .. Waiting for your comments :)
tigerland 2011-05-06 12:43:18
08.05.2020 15:23 # 2
xdesign
My friend, you actually did the most ideal one without asking. Usually we do it for 8000 (light blue) headlights, and 6000 (sharp white) fog :) It looks more effective. It is not clear what the car is when they are equal. It looks contrived. I think it should be good.
08.05.2020 15:23 # 3
onur1980
8000s do not show in the rain or something. 6000k better.
08.05.2020 15:23 # 4
onur1980
Bid headlights original or after
08.05.2020 15:23 # 5
tigerland
headlights orginal valeo :) I add it in the picture, I will behave according to your ideas soon because I am unstable :)
08.05.2020 15:23 # 6
tigerland
Uploaded with ImageShack.us
in this way the headlights were the same as before
08.05.2020 15:23 # 7
metin
xenon is not installed on the halogen headlight ...! If you are going to wear it, use it with lens headlamps, then you will not harm the person you come across.
08.05.2020 15:23 # 8
tigerland
[QUOTE = text] xenon is not installed on the halogen headlight ...! If you are going to wear it, use it with lens headlamps, then you will not harm the person you face. [/ QUOTE]
of course I will do as you say thanks. Well, do you think I should cancel the fog?
08.05.2020 15:23 # 9
tigerland
Should I buy a lens in the fog?
08.05.2020 15:23 # 10
metin
[QUOTE = tigerland] Shall I get a lens in the fog? [/ QUOTE]
exactly. It will be much more beautiful with lensed fog and lens headlight. You will not only get the eyesight of the people, nor the people who drive, etc.
08.05.2020 15:23 # 11
tigerland
partner, I got my headlights adjusted 2-3 meters in front of me, I did not sew them in the air, and the headlight adjustment was good during the examination.
08.05.2020 15:23 # 12
The lens at the point of cutting off the headlight beam provides a much more successful sharpness, but I think it can be used with a more qualified bulb and a smooth headlight adjustment that does not point up.
For example, toyota corolla, honda civici, vehicles such as lenses are xenon-free. not taking it in the eye ...
I believe this is related to the correct adjustment of the headlight with the bulb and headlight quality.
08.05.2020 15:23 # 13
tigerland
In order to prevent the engine from being observed at the lowest level and the in-vehicle control at the lowest level, all settings are currently at the lowest level.
08.05.2020 15:23 # 14
metin
The [QUOTE = CeCoLi] headlight provides a more successful sharpness at the point of interruption of the headlight, but I think it can be used with a better quality bulb and a smooth headlight adjustment that does not look up.
+1 Thumbs Up
08.05.2020 15:23 # 15
tigerland
friends, I say, whether I stay or send back 6000k to change whether we open another topic and we will handle it :) you tell me your opinion what should I do? 8000K headlights fog 6000K back and make headlight fog 6000K? my question is thanks to the friends who helped this
08.05.2020 15:23 # 16
I am glad that I have 6000K lenses in my car, but as far as I know, it takes eyes in normal headlights, especially a complete disgrace in HYUNDAI ACCENT ERA ...
08.05.2020 15:23 # 17
metin
The most beautiful illuminator in the xenon is 4350K. But if you want something a little different, do something between 6000-8000, if you are going to wear lenses with lenses and fog, do not. Thanks to the lens cut line, the light does not dissipate, instead of the mountain stone, it only illuminates its path.
The tastes and colors are indisputable, do as you wish, but don't miss the rope.
08.05.2020 15:23 # 18
tigerland
Although the color of xenon lighting is known as Blue, it is actually “White” in the color scale. The color of the Xenon lamp is perceived as Blue only when compared with the warmer yellow color and when the Xenon lamp starts lighting within the first 30-60 seconds. Compared with daylight, Xenon light will be seen to be white.
The temperature values of the colors are made according to the "Kelvin" rating.
For example, the colors of light; Red 1800K, Yellow 4000K, White 5000K, Crystal White 6000K and 8000K-12000K are also from Light Pink to Dark Blue.
The “K” value, which mostly indicates this color temperature of the light, is mixed with “amount of light” in Xenon lighting and it is believed that an 8000K or 10,000K Xenon lamp will provide more lighting. This is completely misinformation.
The best example of this is the "Black" color. Although Black has the highest Kelvin value, it cannot be used as any light source and does not emit any light / brightness.
The amount of light / brightness that a light source gives to its environment can only be understood from the values of “Lumen”.
Therefore, the illumination / light amount of 8000K and 10000K Xenon lamps is between 2,600 - 2,400 Lumens. However, the illumination power of 6000K Xenon bulb is min. It is 3,200 Lumens and is at least 19-25% more than others.
Lighting Powers by Kelvin Degree
3500K Gold Yellow 3,600 (lm)
6000K Pure White 3,200 (lm)
8000K Purple White 2,600 (lm)
10000K Pure Blue 2,400 (lm)
A xenon bulb between 3500K - 6000K is recommended because it gives more light and the closest white color to daylight is 6000K, providing the driver with a much safer vehicle and providing the most ideal brightness in any weather.
The main problem with 8000K, 10000K and higher Xenon lighting is that the road is much harder to see than 6000K Xenon lighting, especially in snowy and foggy weather.
After this information, I decided to send it back and choose 6000K. Thank you to the friends who helped.
08.05.2020 15:23 # 19
metin
we request we have been enlightened about the subjects that we do not know (:
08.05.2020 15:23 # 20
tigerland
You were enlightened with xenon :)
Page : / 2
