xenon headlight problem
08.05.2020 18:10 # 1
ERDINC
One of my xenon headlight bulbs exploded and the other solid brains are intact now I can not find the same light bulb.
08.05.2020 18:10 # 2
kursat3006
You find the light bulb or whatever
08.05.2020 18:10 # 3
Bunyamin.Kar
Xenon shops are now one by one with an exploding bulb.
08.05.2020 18:10 # 4
If you are on the Anatolian side, you will surely find a single bulb in the iron automotive on the road leading to the rose water from the bridge of maltepe rose and furkan tuning on the way to bakkalköy.
08.05.2020 18:10 # 5
Bugra
How did the 400 lira product explode + no brand? Have you searched from the net? the worst case is that you only get 2 xenon bulbs. Even if you find and wear the same brand light bulb, they will be different. because it will be different from each other as the burning hour. Make sure there is not much difference between the most expensive and the cheapest. .
08.05.2020 18:10 # 6
ERDINC
After buying the vehicle from the previous owner, the vehicle was fitted with a 2010 model
08.05.2020 18:10 # 7
fatihgg
Don't have the brand name label barcode vss on balance?
h and watt information should be labeled on the cables of the bulb.
