Xenon for 206 h4 frosted headlight
08.05.2020 18:16 # 1
fatihcan1912
hello, I am thinking about wearing xenon with 206 model h4 headlamp with 2000 model brand and I wanted to learn the experience from those who made this application before or like it would be bad or not. I can say better, osram nightbreaker is no different from normal headlight, I think what should I do in h4, or should I wear new type transparent headlights and add normal white h7 headlight or something, but if I buy a transparent headlight between 150-190, I can't wear xenon, if I buy xenon, I will buy h4 type as brand what are your suggestions
08.05.2020 18:16 # 2
mustafa_nalcacioglu
If the xenon is not very good in frosted glass, it is very problematic for the vehicles that come across and for your road view, if you want to make a sellektor, you can have a 90 / 100w narva or philips bulb together. we are using 90 / 100w bulbs.
08.05.2020 18:16 # 3
mustafa_nalcacioglu
In the meantime, I forgot that if you buy a new type of headlamps and install it, this is not a problem, since the old headlamp is h4, the new headlights are double tall, h7 is separately lit, that is, when you switch on the high beams, both lights will light up soon, but at h4, the short lights will be closer if you connect the new type of light. It will only end up on the sellektor as a double, then you should throw a diode from the headlight role to the leg of the short, but an electrician who understands it takes care, but a little bit of detail is not understood by every electrician. the mustafa_nalcaciogl 2014-02-02 00:25:57
08.05.2020 18:16 # 4
fatihcan1912
Thank you, since Mercedes' headlight glass is real glass, 100w bulb created a lot of problems, I used 100w bulb in my previous letterpress and taunus, but I do not think 100w because of 206s plastic headlight plastic, but because of the heat, thank you for lighting.
