xenon fogging
08.05.2020 16:05 # 1
deamod
Friends, can I put the xenon on the fog myself? If the fog is going to be lensed, the illustrated explanation will be better.
08.05.2020 16:05 # 2
I think the electric installation of the vehicle is 2000 model is the old medicine. You shouldn't have BSI etc in your vehicle. There should be no breakdown, heat, burning condition from that pain ...
You can do it yourself if you have a little bit of electrical power and sting ability. Of course, there must be a hand in hand. Because the ballasts of the xenon are outside, you have to puncture the back cover of the fog light and enter the ballast. You should also be able to attach the ballasts of xenon to a solid location. Otherwise, it hangs in the pits, etc., as soon as the problem goes out ...
08.05.2020 16:05 # 3
deamod
Uh, my hand is good, good electricity, oh my man, I do not understand, but I can not get it, I have a lot of 240 nuts, we wear it like a normal headlight?
08.05.2020 16:05 # 4
[QUOTE = deamod] Uh, my hand is good, I don't understand my good electricity, oh my sweetheart, but I can not get it, I have a lot of 240 nuts and I do not wear it like normal headlights? [/ QUOTE]
If you can, you can ...
You will do just as it was attached to the normal headlight. There is no difference. There is no functional difference between headlight and fog light anyway. They both work in the same way. Only sometimes bulb types and sockets may be different. The fog is usually H1. Headlights can change according to the situation H4 H7 H1 etc.
"" "If there is a mummy," "" would be much more beautiful if you put the xenon bulb in place by inserting the fog head light and pierce the cover so that it does not get water well.
If you do that, you will get a better result. There may be problems with light scattering, inefficient lighting, dust inlet, etc. in rush and inadequate assemblies.
08.05.2020 16:05 # 5
deamod
Now I can not say anything clear, I have more information, except for the subject of piercing, but I will have more information when xenonlar and fog are in my hand. I open the threads to shed light on it though ...
