x-desing fog light
08.05.2020 15:05 # 1
masumserseri
mrb friends.
About 20 days ago, I bought a 206 x 206 x-desing HDI vehicle. I did not see anything for you. I am waiting for your help if there is arkasa, which cuts the bumper on the model and applies fog shadow.
Thank you for your help, I wish you good forms
08.05.2020 15:05 # 2
MemoTech
The hood inside the Right and Left fenders has a plastic flap pocket on the side facing the bumper. You can see if there is a fog slot inside the bumper by opening those covers. Anyway, it seems like the access point for removing and installing the fog lamps bulbs.
08.05.2020 15:05 # 3
oguzhan29
thanks for your information i think fog light come on we are waiting for comments from some more knowledgeable friends
08.05.2020 15:05 # 4
Muhammet CAKIR
I have a 2003 model xline HDI brother, if you look at the front bumper, you will see that there is a thin blade of fog light at the bottom. He said, but he believed it was everyone after doing it. Finally, when we cut it, cut it according to the headlight or cut some of the headlamps smaller than the hole. )
Muhammet ÇAKIR 2011-02-09 22:58:33
08.05.2020 15:05 # 5
masumserseri
Thank you, tomorrow, the first heat will be to be concerned with this. Efe master said 80 to 2 fog lights. I will get a little more plus. depending Standards Confused the masumserser 2011-02-09 23:09:22
08.05.2020 15:05 # 6
Muhammet CAKIR
You'll tie it on yourself :) + your squad is just but don't forget to buy the headlamp relay otherwise you will change the key very much :))
08.05.2020 15:05 # 7
masumserseri
do you think i can fuck then i will not hurt Wacko
08.05.2020 15:05 # 8
Muhammet CAKIR
No yaw, it is not the worst possible if you go to the repair shop :)
08.05.2020 15:05 # 9
masumserseri
you brought me to the gas, it would be good to try me.
08.05.2020 15:05 # 10
Muhammet CAKIR
besides, my brother has to give money to the world, to improve himself on the side and to bring himself cheaper :)
08.05.2020 15:05 # 11
masumserseri
What do you think is the mechanic to do these things? The parking sensor alarm or something all ready man will just cut and drill and assemble.
By the way, what did you cut the bumper with decoupage or something?
the masumserser 2011-02-10 01:06:05
08.05.2020 15:05 # 12
Muhammet CAKIR
no bro bro pierced with the tip of the soldering machine with the tip of the soldering machine, first I pierced with the tip of the soldering machine, I already pierced with it, I spotted it with the spot, I cut it with the knife, I cut it with the holes, I cut it with the tools, you have whatever tools you have with it, you have a tool, you can fix it with whatever tool you have. You can use it on the drill, you can use it. For example, you can fix it.
08.05.2020 15:05 # 13
Muhammet CAKIR
brother bro key
Muhammet ÇAKIR 2011-02-10 12:25:04
