Würth fuel system cleaner
08.05.2020 19:34 # 1
xmen
Friends I have 1.6 HDI vehicle. I used about 167 thousand wurth .. now it throws a little bit of smoke, is it really cleaning the fuel system or is there a problem.
08.05.2020 19:34 # 2
madblueblacksea
I also used it because it was a slight misfire at idle. It is useful to use the vehicle at a little speed to be more effective. It is possible to think that he started spraying excess fuel and throwing smoke from the rich mixture because he cleaned the injector soot.
08.05.2020 19:34 # 3
xmen
[QUOTE = madblueblacksea] I used it too because it was a slight misfire at idle. It is useful to use the vehicle at a little speed to be more effective. It is possible for a person to think that he started spraying excess fuel and throwing smoke from the rich mixture because he cleaned the injector soot. [/ QUOTE]
Thanks for your answer .. It seems like there is a relief in the engine sound. When I smell the gas, the smoke increases. Let's see if I finish the warehouse. What will happen?
08.05.2020 19:34 # 4
madblueblacksea
When it burns the gas, it is usually from the flowmeter egr to turbo. High rpm cuts smoke at constant gas. No, you can doubt the injector if it doesn't cut
08.05.2020 19:34 # 5
darklebron
If we buy this würth fuel system cleaner, how much gas should we get on it?
08.05.2020 19:34 # 6
xmen
On average, each box already set for a warehouse
08.05.2020 19:34 # 7
darklebron
Well, if we put half a box in half a store, would it be useful
08.05.2020 19:34 # 8
xmen
Well, my teacher is like that, but I don't know if it will work or not.
08.05.2020 19:34 # 9
Gokcesel
I need to fulle the tank to use it, I think I will use it and adjust it accordingly :)
08.05.2020 19:34 # 10
xmen
Sir, the instructions for use are enough for one box of approximately 50-60 liters of fuel.
08.05.2020 19:34 # 11
Gokcesel
OK thanks .
08.05.2020 19:34 # 12
[QUOTE = darklebron] so if we put half a box in half a store, would it be useful [/ QUOTE]
half a box of useless teachers, you have to empty all of them and they should be used at a high speed of 20 km but it works.
08.05.2020 19:34 # 13
madblueblacksea
[QUOTE = sonerkyl] [QUOTE = darklebron] but if we put half a box in half a store, would it be useful [/ QUOTE]
Let's make it 100, be solid :) We have to do the diesel car is clogged early.
08.05.2020 19:34 # 14
KILIC
I don't know how real, but I heard from a truck driver and a taxi driver. In diesel engines, it is cleaned even when hydraulic oil is put in a filled tank.
08.05.2020 19:34 # 15
emrepunar
I think that psychologists have used both motor and gasoline additives, and I think they have seen psychological benefits. Technically, I would use all authorized and special services.
08.05.2020 19:34 # 16
madblueblacksea
[QUOTE = emrepunar] I think psychologically, I believe that it is psychologically beneficial for those who see that I have used both motor additive and gasoline additive. technically, they would use all authorized and special services.
You think your psychology is bad enough not to notice whether the fluctuation in idling has improved or not. The important thing here is what the expectation is. If you use it stopped while it's okay, you will definitely not be able to see it. Not a performance-saving fuel-saving product
madblueblackse to 2016-01-02 13:07:02
08.05.2020 19:34 # 17
emrepunar
estar. I said nothing psychological incident. I mean, it seems like it happened to us because we conditioned ourselves to him, after a certain time, he understands that everything is normal.
08.05.2020 19:34 # 18
madblueblacksea
[QUOTE = KILIÇ] I don't know how real but I heard from a truck driver and a taxi driver. In diesel engines, the tank was cleaned even when a bottle of hydraulic oil was placed [/ QUOTE]
Don't do anything like that. Yes, truckers would do it, but not in electronic engines, but in black layout engines you know. If I try to explain it in detail, you will be worried about writing :)
08.05.2020 19:34 # 19
xmen
[QUOTE = emrepunar] I think psychologically, I believe that it is psychologically beneficial for those who see both the motor and gasoline additives and I have not seen any benefit. technically, they would use all authorized and special services.
Well, I don't think so, because as far as I can see, there is an obvious reduction in the smoke that comes out, and there is a relaxation in the sound of the engine. By the way, I have been using it for about 270 km. As our friend Madblueblacksea says, what matters is the expectation.
08.05.2020 19:34 # 20
KILIC
[QUOTE = madblueblacksea] [QUOTE = KILIÇ] I don't know how real but I heard from a truck driver and a taxi driver. In diesel engines, the tank was cleaned even when a bottle of hydraulic oil was placed [/ QUOTE]
No, I wouldn't try it :) I am against all of these contributions. :)
Page : / 2
