write airbag or pretensioner seat belt fault on the screen
08.05.2020 18:53 # 1
hatayli
friends, as I wrote in the title, this article appears on the screen. the horn does not work, and esp asr faulty appears. does it all have to do with the signal arm, does the spool underneath the steering cause problems.
08.05.2020 18:53 # 2
ankaonur
I don't know if it will work, but the same problem happened in the fort's focus of the friend. There is a box-like part at the bottom of the steering wheel, it was broken, the repairman said, this piece both lights the airbag fault lamp and cancels the horn,
I do not know the exact name, but he took the piece for 120 TL from the internet and got it installed by the master.
I don't know if it would work, but it was simple, the part had to be changed
08.05.2020 18:53 # 3
hatayli
Thanks for the answer, where can I find this piece exactly?
08.05.2020 18:53 # 4
korkusuz202
Exit if you can find a signal arm as a team change. Airbag winding and chip inside are malfunctioning over time. In my case, the airbag light stays on and the horn does not sound.
korkusuz202 2014-11-18 22:27:58
08.05.2020 18:53 # 5
hatayli
What are the prices?
08.05.2020 18:53 # 6
hatayli
[QUOTE = fearless202] bounce if you can find a signal arm as a set. Airbag winding and chip inside are failing with time. In my airbag light remained burned and horn did not sound.
[/ QUOTE] Thank you for your answer How much are the prices of these arms
08.05.2020 18:53 # 7
korkusuz202
I changed 206 to 150 or so, and if the stone cracks, 200 does not exceed.
08.05.2020 18:53 # 8
Alicilik
Sir, you wrote the same problem again. You mentioned the same problem in the title.
Problem COM2000 module behind the steering wheel with signal arms connected. You can find new ones in Cikamsi around 150tl and in pieces up to 400tl. The one suitable for your vehicle in the service is around 600 TL.
08.05.2020 18:53 # 9
peugeotefe
The fault of your fault is exactly com 2000.
If you write your car model exactly, I will help with zero and exit
08.05.2020 18:53 # 10
hatayli
[QUOTE = peugeotefe] Failure of your fault is exactly com 2000.
If you write the model of your car exactly, I will help with zero and exit [/ QUOTE]
2006 model 16. HDI premium peugeot 307. thank you in advance.
08.05.2020 18:53 # 11
peugeotefe
If your vehicle has esp, your com2000 300 TL will be compatible with your vehicle.
08.05.2020 18:53 # 12
hatayli
[QUOTE = peugeotefe] If your car is esp, your combo robust vehicle will be compatible com2000 300 TL. [/ QUOTE]
I have an esp, headlight sensor, rain sensor in my car.
08.05.2020 18:53 # 13
Alicilik
Zero for 250 yaw naapt
08.05.2020 18:53 # 14
peugeotefe
[QUOTE = Buyership] [QUOTE = peugeotefe] If your vehicle is esp, your combo will be compatible with your com2000 300 TL. [/ QUOTE]
If zero is 250 TL, I want to order 10 pieces. Is it possible?
