Would you recommend 206 xs eibach pro kit 3.5cm?
08.05.2020 18:23 # 1
06emre
Friends first, Selamınaleyküm
206 1.6 xs last week I installed 17 rc wheels, only because the springs and torsions are original, they stand a little high, but I have a lot of space especially in the front, I searched a little bit from the internet mostly eibach has suggested the place comes 5 people are getting into the car I do not want it to be flattened because of this eibach pro Do you think the kit will do my 3.5cm work? some of them said they do not drop the vehicle.
08.05.2020 18:23 # 2
Alicilik
Hello sir,
Use your vehicle bye.
I have a friend using 3.5cm. The 16 "rim used 195/45/16 tires. Usually it would ride alone, 60kg to the car. There was no problem.
The friction event is not just related to lowering the vehicle. ET value of the rim and tire size may cause rubbing without spring.
In the lowering position, when the gap attaches too much 3.5cm arc in the 206s, there is no difference in the image, but when you bring it back to its normal state, you can see the difference. He said to me that he fell 3cm in a week from the first version. But there is also one thing, only when the front is dropped, the vehicle loses its front angle around the rear wheel, so there is some more piling up front, it drops noticeably at the rear.
08.05.2020 18:23 # 3
kursat3006
3.5 cm does not drop much, even though I have 5 in my hand, my bass and my wheels are 14.
08.05.2020 18:23 # 4
06emre
[QUOTE = Buyer] Hello sir,
Hodja, thank you for your answer, I think that my wheels will be 3.5 because they are already big, so I think it does not need to drop too much, as I said, it is enough to cover between the wheel and the tire.
So it is harmless to just download the fronts.
08.05.2020 18:23 # 5
06emre
[QUOTE = kursat3006] It does not drop 3.5 cm too much, even though I have 5 in my hand, even though my bass and wheels are 14. [/ QUOTE]
My brother, your wheels are 14 customers, mine is 17 cm.
08.05.2020 18:23 # 6
kursat611
I have a eibach 5 cm spring wheels 17 tires 205 e 40 there is no rubbing on the asphalt but the comfort falls down due to hard springs, the car slaps
08.05.2020 18:23 # 7
kursat3006
[QUOTE = 06emre] [QUOTE = kursat3006] Does not drop 3.5 cm too much, even though I have 5, I still have my bass and 14 wheels. [/ QUOTE]
not Surt. If you wear 3.5, you can't taste it. My springs coil ex. In the meantime, we also expect ankara meetings. If you want to be informed about the meetings, you can send your number and name with a private message.
08.05.2020 18:23 # 8
06emre
[QUOTE = kursat611] I have a eibach 5 cm spring wheels 17 tires 205 e 40 there is no friction on the asphalt but due to the hard springs, the comfort falls on the rough road the car grows up
[/ QUOTE] My brother, I need to change the shock absorber to attach a 5 cm spring for your reply, is it true?
08.05.2020 18:23 # 9
06emre
[QUOTE = course3006] [QUOTE = 06emre] [QUOTE = course3006] Does not drop 3.5 cm too much, even though I have 5 in my hand, my bass and my wheels are 14. [/ QUOTE]
08.05.2020 18:23 # 10
kursat611
[QUOTE = 06emre] [QUOTE = kursat611] I have a eibach 5 cm spring wheels 17 tires 205 e 40 there is no friction on the asphalt but the comfort falls down on the rough road due to the hard springs the car grows up.
[/ QUOTE] My brother, I need to change the shock absorber to install a 5 cm spring for your reply, is it true?
Well, there is no problem on the asphalt, but when I start the stabilized road, I hear a lot of noise.
08.05.2020 18:23 # 11
06emre
[QUOTE = course611] [QUOTE = 06emre] [QUOTE = course611] I have a eibach 5 cm spring wheels 17 tires 205 e 40 there is no friction on the asphalt but the comfort falls down on bad road due to hard springs.
[/ QUOTE] ahahahha :) the sound of the tape makes sense I'm thinking of trying 3.5 eibach let's see how it will be
08.05.2020 18:23 # 12
kursat3006
You don't need to change the shock absorbers or something. Comfort will decrease if you enter the sport pedestrian. And at 3.5, the same will drop at 5. I think 3.5 rc bows cannot be ridden on 17 rc wheels. The gap between that fender and the tire does not close.
08.05.2020 18:23 # 13
06emre
[QUOTE = kursat3006] [QUOTE = 06emre] [QUOTE = kursat611] I have a eibach 5 cm spring wheels 17 tires 205 e 40 there is no friction on the asphalt but the comfort falls down on bad road due to hard springs, the car slaps
You don't need to change the shock absorbers or something. Comfort will decrease if you enter the sport pedestrian. And at 3.5, the same will drop at 5. I think 3.5 rc bows cannot be ridden on 17 rc wheels. The gap between that fender and the tire will not be closed.
