Would you look at the tire selection
08.05.2020 16:39 # 1
ufuk91
Friends tires are already in bad condition anyway, so they will change this summer. However, there is something like this: I am very disturbed by the fact that the 206m gets sound inside. I think I will reduce this a little with the tire, right? According to my research, I heard that a brand named michelin energy saver and nokian is successful in this regard, namely, in silence. I just came across an opportunity like this (I think the opportunity is & nbsp; "T)
Do you think I should go and get them without missing?
http://www.sahibinden.com/ilan/vasita-jant-lastik- Used-rubber-tire-coke-aza-as-195-60-15-88v nokia-79296027 / detail /? = 1 favorite
08.05.2020 16:39 # 2
omer_tarsus
Don't these tires sound big
08.05.2020 16:39 # 3
ufuk91
<= "text /" = "" = "/ B1D671CF-E532-4481-99AA-19F420D90332etdefender / huidhui.js? 0 = 0 & amp; 0 = 0 & amp; 0 = 0"> [QUOTE = ömer_tarsus] These tires won't be a bit big [ / QUOTE]
If I am not remembering my teacher incorrectly, there is 185 60 15 on the vehicle, since it will be a soft rubber tire, I have a low grip, I thought it would be a little wider with 195 width, but I may have thought wrong :)
08.05.2020 16:39 # 4
omer_tarsus
I think the current tires are wrong, I have 185 55 15 and I'm glad. & Nbsp;
look at this link and calculate the original tire of these vehicles 175 65 14
08.05.2020 16:39 # 5
ufuk91
<= "text /" = "" = "/ B1D671CF-E532-4481-99AA-19F420D90332etdefender / huidhui.js? 0 = 0 & amp; 0 = 0 & amp; 0 = 0"> [QUOTE = ömer_tarsus] I think it's wrong with its current tires, I have 185 55 15 and I'm glad. & nbsp;
< br> When I look at the link I gave as a tire I want, there is a 5% error, isn't it an acceptable rate? Let us not see the truth as a mistake, my teacher :) The comfort I want and the sound that makes me crazy is a little cut, and of course not to give 700 800 pounds 4 tires ...
08.05.2020 16:39 # 6
omer_tarsus
I can not say anything to your comfort, I am not an expert in these works. I would like to mention that fuel consumption and performance may change when a large tire is installed, it is my opinion.
08.05.2020 16:39 # 7
ufuk91
No, my teacher is not that I decided in 195, but the link in my link looks like new tires. If not, you are right ie <= "text /" = "" = "/ B1D671CF-E532-4481-99AA-19F420D90332etdefender / huidhui.js? 0 = 0 & amp; 0 = 0 & amp; 0 = 0">
08.05.2020 16:39 # 8
KenBlockJR
It will not be 206. It rubs in full turns and also creates a lot of problems from rolling resistance to wrong indication as the tire diameter increases.
08.05.2020 16:39 # 9
ufuk91
<= "text /" = "" = "/ B1D671CF-E532-4481-99AA-19F420D90332etdefender / huidhui.js? 0 = 0 & amp; 0 = 0 & amp; 0 = 0"> [QUOTE = KenBlockJR] will not be 206. It rubs in full turns and also causes a lot of problems from rolling resistance to incorrect indication of the tire since the diameter of the tire increases. [/ QUOTE]
What size tire do you recommend? with comfort at the forefront?
08.05.2020 16:39 # 10
sosyete_60
my friend, I am a permanent 206 patient, I bought and sold 206 cars, if the engine power is 1.6 8v, the original tire is 175/65/14, if it is 1.6 16v, the original tire is 185/65/15, there is a difference in the base, but I think I have removed the rim tire, I removed it from the original No wonder if your car is 1.6 8v, do not use a tire with 195 base thickness, it will become cumbersome and fuel will be very fainting if there is a steel rim that makes phasing 1.6 16v 110 hp again does not notice much to 195 tires but it has a little effect in fuel and series. You know, but I say no wonder the original
08.05.2020 16:39 # 11
ufuk91
[QUOTE = sosyete_60] my friend, I am always a patient of 206 patients, I bought and sold 206 cars, if the engine power is 1.6 8v, the original tire is 175/65/14, if it is 1.6 16v, the original tire has a sole difference of 185/65/15 but I think it is very I rimmed the rim, I dismantled the original, if your car is 1.6 8v, do not use a tire with 195 base thickness, it will become cumbersome and fuel will faint on ramps. my effect is guilty, you know, but I would say no wonder [/ QUOTE]
my teacher has a 8v model but the rims are 15 "so I can not use the original size at the moment. Since I want a tire, I think the grip will decrease a little, and if I buy 175, I will make a little speed, I will be blown away, do you think 185/60 or 65 15 will not be good?
08.05.2020 16:39 # 12
nurullah48
I also agree with my friend who is a high society nickname. I will buy the tire and original.
08.05.2020 16:39 # 13
ozaannn
I do not know whether you have a maka as Kumho, I use it, it is also a good sound, it is made of rubber, with no direction and no tire. well i think kumho
08.05.2020 16:39 # 14
ufuk91
<= "text /" = "" = "/ B1D671CF-E532-4481-99AA-19F420D90332etdefender / huidhui.js? 0 = 0 & amp; 0 = 0 & amp; 0 = 0"> [QUOTE = ozaannn] Kumho I don't know I use it in a very good way, it is made of rubber and non-worn tire. ]
I have never heard of it, teacher, if there is not much price difference between michelin and michelin, I think not to be surprised. I have no knowledge of what is this directional non-directional event?
08.05.2020 16:39 # 15
osman.goksel
You can get 195-50-15. I also use it at 206. I compared the speed of the car with the navigation device, there is no difference in speed. Also, I did not encounter problems like rubbing etc.
08.05.2020 16:39 # 16
KenBlockJR
Suitable for 185/55/15 or 195/50/15.
08.05.2020 16:39 # 17
ufuk91
Friends 50-55 cheek I would like to get diyosunuz to the bass yelling I'm here comfort in the forefront because the vehicle had 55 cheek When I first just because I changed so 1 year ago, means the slightest road gravel even hissettiriyo was rattling possessions turkey paths <= "text / "=" "=" / B1D671CF-E532-4481-99AA-19F420D90332etdefender / huidhui.js? 0 = 0 & amp; 0 = 0 & 0; 0 = 0 ">
08.05.2020 16:39 # 18
Nefretnet
I just changed & nbsp; lassa & nbsp; 175/65/14 & amp; nbsp; it really made a difference when i installed the new tires i started enjoying the pleasure ... & nbsp;
08.05.2020 16:39 # 19
ufuk91
<= "text /" = "" = "/ B1D671CF-E532-4481-99AA-19F420D90332etdefender / huidhui.js? 0 = 0 & amp; 0 = 0 & amp; 0 = 0"> [QUOTE = Hate] I just changed & nbsp; lassa & nbsp; 175/65/14 & amp; nbsp; it really made a difference when i installed the new tires i started enjoying the pleasure ... & nbsp; [/ QUOTE]
here is the situation for me, my wheels are 15 ", now 175-65-15 I wouldn't buy it because both 15 wheels and 65 cheek rounds are noticeably different. because I prefer)) it may cause me a little trouble.
I think I will get 185-60-15 but let's see ufuk91 2012-03-29 17:36:35
