Would you like a chip box to partner car
08.05.2020 16:12 # 1
aopena
friends, I have a chip box on this vehicle. Does anyone know if the speed contributes too much? For example, how many effects will contribute to the effects of my life?
08.05.2020 16:12 # 2
Engin Tepe
I have researched also does not cause any problems during the examination. You can get a healthy 25 hp and a 35 hp power from a 90 hp engine.
When you get max power (30-35 hp) you will encounter black smoke blows from the exhaust.
Since the rest takes full cycle power from the turbochargers at the lower speeds, you will accelerate without hitting the top speeds, so you will not burn too much. strong> It is a very useful sanction when used in healthy, but if you use it unhealthy, you will shorten the life of the engine.
& nbsp;
& nbsp;
08.05.2020 16:12 # 3
aopena
When you say unhealthy, how much does it cost?
08.05.2020 16:12 # 4
sedataksu
Two types of applications can be made to this tool.
1. There are ready-made kits called Box, you can remove the cable that goes to the injectors, which is very easy to install and disassemble, and plug the other end of the cable into the box, to the cable that goes to the injectors. You get a power increase of about 25 hp. The Ecu information of the vehicle is copied by connecting through the ODB II port, arranged according to your wishes and loaded to the vehicle. The figures are made like 700 700 TL. and waiting 20 seconds while stopping to extend the life of this turbo.
08.05.2020 16:12 # 5
Engin Tepe
How do you say [QUOTE = aopena] unhealthy? How much does it cost? .peugeotturkey.com / smileys / smiley1.gif "height =" 20 "width =" 20 "border =" 0 "alt =" Laugh "title =" Laugh "/>.
If you do not pay attention to the engine & nbsp; and damages the turbo and shortens its life.
08.05.2020 16:12 # 6
aopena
Well, what I don't understand is how it increases. What does it do? I do not understand what a device is changing. & nbsp;
08.05.2020 16:12 # 7
Engin Tepe
Priority increases the turbo pressure, the turbo is stronger at lower speeds, so the field is effective.
