Would this cd player replace the cassette player?
08.05.2020 18:58 # 1
samet2461
friends I have a cassette player originally on my 2004 model 307 XT. Will this RD4 cd mp3 player tape be compatible with my car. can i use the handle.
samet2461 2015-01-06 21:24:15
08.05.2020 18:58 # 2
serdaralisan
WHEN IT IS COMPATIBLE, SO SOCKETS ARE FLASH COMPLETELY DIRECTLY USED 2004 I HAVE INSTALLED THE CD PLAYER OF THE TOP MODEL FOR MY VEHICLE.
08.05.2020 18:58 # 3
samet2461
[QUOTE = if you are serdarra] If it is COMPATIBLE, SO SOCKETS ARE COMPLETELY DIRECTLY USED 2004 I HAVE INSTALLED THE CD PLAYER OF THE TOP MODEL TO MY XL, I SOLD THE DAY IN THE CASSETTE PLAYER.
Tape recorders that steal a track on our vehicles. These are the new models of the 2008 model or something. mp3 is playing. does it fit
08.05.2020 18:58 # 4
xmen
If it is compatible, I would like to buy this tape from my tape, if you have friends who have 2006 model premium 307, I am a suitor.
08.05.2020 18:58 # 5
albayman
as far as i know this is in rd4 makeup cases. it seems that the pin numbers in the sockets of the old cases do not hold with this ...
08.05.2020 18:58 # 6
Alicilik
Primarily, socket structures are different. What will you say,
In vehicles with van construction
106
206
306
307 (2002-2005)
Tape sockets are of ISO type. This type of socket has two large sockets of 2 * 4. Of these sockets, 8i are for hoaprltors, other 8i are for data and electricity.
Cant
207
307 (2006-2008)
308
In vehicles such as tape, it is the smaller socket of the IS, which we call Fakra, and the main socket with sockets in other systems operating from the line of life. The ISO socket is smaller in Fakra and has the same arrangement. In addition to these, it is plugged in small sockets for connections such as bluetooth, navigation, HD radio, Aux, USB, and so on. You will understand that it has a complicated structure.
It is likely to work when it comes to the subject of operation but you may need to buy or make a special cable to turn this life device from the van to the ISO socket of the Van vehicle.
In the van-built vehicle, the ISO socket has a female structure. For the converter, it is necessary to find the male socket that meets this and connect this male socket with the female Fakra socket. Of course, while doing this, you have to check the original inputs of the tape and the outputs of the vehicle and arrange them accordingly.
When we do this, we should test its operation, if it works, if the pip pip sound sounds, it will come, it will be necessary to connect the vehicle with the software and introduce the chassis number of the vehicle to the tape.
If you find this tape in Ankara, we will try.
08.05.2020 18:58 # 7
albayman
If there is curiosity and interest, it can be dealt with, and we are informed.
but if there is no time, connecting a direct usb / sd converter module would be a more practical, easier and cheaper way.
you also have the chance to play from usb or sd card, you don't have to deal with cd.
I had the original tape recorder in my old safe 307 car. I installed a usb module:
http://forum.peugeotturkey.com/forum_posts.asp?tıd=20171&title=307-cd-changer-alternatifi-cozuldu-resimli-montaj
