Would there be a 17cm reporter at the front doors?
08.05.2020 17:33 # 1
arachnid
hello friends
If I buy 17cm speaker on the front doors, will it fit? & nbsp;
product link I want to buy:
08.05.2020 17:33 # 2
herry
Is your vehicle 206? If 206, then front 16 back 13
08.05.2020 17:33 # 3
arachnid
thanks. yes 206. but avoids 16.5cm. I am waiting for your help just because I do not want to remove the flooring to measure. I tried hard to plug it in. & nbsp;
arachnid 2013-04-29 14:04:03
08.05.2020 17:33 # 4
KenBlockJR
front 16.5
rear 13
17 to the front
08.05.2020 17:33 # 5
arachnid
thanks . I corrected it wrong.
08.05.2020 17:33 # 6
mev347
I have 17 mid team
08.05.2020 17:33 # 7
samet206
the precautions are 16.5 or 16 if I think it will be 17 but the depth is important.
08.05.2020 17:33 # 8
arachnid
Thanks to everyone who answered.
08.05.2020 17:33 # 9
bjkamil
friends I like the sound system for ford focus. bass and treble shoots solid. To get the same sound quality we need to get my mid team to our vehicles.
08.05.2020 17:33 # 10
rolandgarros
it is up to me to say good luck LOL
08.05.2020 17:33 # 11
arachnid
I finished the speaker installation without any problem. the sound quality got better as I wanted. As you said, there was no problem at 17cm. it would even be a larger speaker. as long as it does not exceed the following measures; the dimensions of the speaker socket diameter: 14.3 cm, depth: 5.8cm-6.5cm (the depth of the bottom of the speaker socket is not the same. so i wrote both dimensions). It is definitely writing somewhere, but with this article, I will give ear fullness to you, my friends. I stripped the cable and taped the new speaker cables.
regards.
arachnid 2013-05-05 14:43:21
08.05.2020 17:33 # 12
Gokhan Cetin
[QUOTE = arachnid] I finished the speaker installation without any problems. the sound quality got better as I wanted. As you said, there was no problem at 17cm. it would even be a larger speaker. as long as it does not exceed the following measures; the dimensions of the speaker socket diameter: 14.3 cm, depth: 5.8cm-6.5cm (the depth of the bottom of the speaker socket is not the same. so i wrote both dimensions). It is definitely writing somewhere, but with this article, I will give ear fullness to you, my friends. I stripped the cable and taped the new speaker cables.
regards.
[/ QUOTE ]
Good luck listening to good music
