Would it be 215 * 40 * 17 to 206?
08.05.2020 17:29 # 1
muku
friends, I know it would be 17 wheels, but mine is different because the base is 215 :( I have 215 * 17 wheels, I would like to evaluate this.
08.05.2020 17:29 # 2
MagicPerformance
It will be 40 cheeks, but use a maximum of 200 bases in width and rubs over. I also did not understand how the rim base is 215 :)
MagicPerformance 2013-04-01 15:26:04
08.05.2020 17:29 # 3
muku
[QUOTE = MagicPerformance] It has 40 cheeks but use maximum 200 bases in width. I also don't understand how the rim base is 215 :)
Can't I wear the rim base 215 in my hand? or where do I turn the steering wheel?
08.05.2020 17:29 # 4
umut_25
Sir, I use 215/55/15. I'm very pleased. The previous owner was using 225/45/17. He could ride when 3 people were riding in a row. The most suitable rim size for 206 I have researched a lot is 15 "but it can also be 16" using initiative. When the measurements you mentioned are taking passengers in the back, they will definitely drive and tire the car. The suspension is not very good anyway. For that reason, those dimensions will further reduce your already low comfort. If you have the opportunity, I would say go under 50 cheeks and over 16 ".
08.05.2020 17:29 # 5
MagicPerformance
You use 215 in 15 diameters, but rub in 17, and max wall thickness in 17. If you get 40 and 45, the room will be 200 at the bottom of the room.
206 I have tried more than 40 sizes from 14 to 18 so far :)
08.05.2020 17:29 # 6
muku
Suppose I take the rubbing and take the spring 3.5cm or 5 cm team?
08.05.2020 17:29 # 7
MagicPerformance
3.5 cm doesn't work very well, 5 cm is good.
08.05.2020 17:29 # 8
aknard
Do not surpass 205/40/17 in any way, even if you say that I would definitely wear 17;)
08.05.2020 17:29 # 9
MagicPerformance
[QUOTE = aknard] Do not surpass 205/40/17 in any way, even if you say I will wear 17;) [/ QUOTE]
+999999999 :)
08.05.2020 17:29 # 10
muku
[QUOTE = aknard] If you say I would definitely wear 17, do not pass 205/40/17 in any way. div>
08.05.2020 17:29 # 11
umut_25
If only the free rim is coming to you for free and you will buy a tire then 205/40/17 or 205/45/17 alcan is obliged. If the rims are not very good, I would like to put some money on the second hand and buy a more useful rim.
08.05.2020 17:29 # 12
KenBlockJR
Does not rub with 205/40/17 tires
08.05.2020 17:29 # 13
cerci07
Is it suitable for meat si kac 206? try the rim & nbsp;
08.05.2020 17:29 # 14
Barut
I used 215 soles for 17 rims, it rubbed excessively, unfortunately the top of 205 soles is rubbing.
08.05.2020 17:29 # 15
muku
[QUOTE = KenBlockJR] Doesn't rub with 205/40/17 tires [/ QUOTE]
Would it be 205 tires to 215 rims? What do you mean without rubbing in the bidet?
08.05.2020 17:29 # 16
candanxyz
205 40 17 my sizes are very satisfied.
08.05.2020 17:29 # 17
_semihk_
205 base becomes okay .. only when the base grows, the tire expands on the cheek. The sidewall size of the 205-40-17 and 215-40-17 is not the same. 40 means 40% of the 40 base size. I force you to think
